Battery smoke
Old Jun 28, 2025 | 10:26 PM
Robert95's Avatar
Default Battery smoke
Hey guys 2002 cbr f4i
I don’t think this has anything to do with it but I replaced my front headlight bulbs and when I went riding my running light turned off but I’m able to turn my high beam light on just the light.
I ride home and find out my battery is smoking. I pulled battery and it’s cooked. Everything else seems fine. So my question is what can cause my battery to start smoking? Can replacing the bulbs cause this? I replaced the rectifier and stator 2 years ago. Thanks guys!
Ps. Bulbs are stock replacement H7
Old Jun 29, 2025 | 05:32 AM
Ed Harris's Avatar
First thing to check has to be the regulator, almost certainly the fried battery is due to over voltage. Put a meter on and rev the bike to maybe 5,000, the voltage should not go over 14.8v
Old Jun 30, 2025 | 05:27 PM
Robert95's Avatar
What am I putting the meter on? The regulator?
Old Jul 1, 2025 | 01:09 AM
Ed Harris's Avatar
Across the battery will be fine.
Old Jul 4, 2025 | 03:51 PM
Robert95's Avatar
Regulator was bad. After testing also the battery with old regulator the voltage sky-rocked, new regulator and it all evenly balanced out. This issue did cause my headlights to blow out and my battery to fry itself from the power pushing through it.
Old Jul 5, 2025 | 04:36 AM
Ed Harris's Avatar
Glad you’re sorted :-)
Old Jul 12, 2025 | 09:50 AM
rockpool's Avatar
And like many, you didn't start changing random unrelated parts before analysing the problem and using logic to identify the cause ;-)
Michaud85
Aug 17, 2012 12:57 PM
cbrjohn
May 30, 2012 11:41 AM
thebuch
Dec 24, 2011 01:22 PM
BBirish
Jan 16, 2011 10:24 PM
njdjh2o
Apr 11, 2008 07:20 PM
