Spark plug change interval
Old Mar 25, 2009 | 06:20 AM
MC_spirited's Avatar
Default Spark plug change interval
Do you guys really change the plugs every 8000 miles like ti says in my manual? The P.O. changed them before i bought them, but Ive put over 10000 miles on it at least since then. That is like a set of plugs a season, and then some.
You guys really do it that often? ha, for me eight thousand is often...
Old Mar 25, 2009 | 08:24 AM
some guy #2's Avatar
i changed mine once at 16k and wasn't even thinking about it until close to 30k
Old Mar 25, 2009 | 08:54 AM
Berto's Avatar
My manual recommends "checking" them at 12,000, but it doesn't say replace them. I had things apart over the weekend, so replaced them while I was at it. The local Honda parts guy kind of laughed. He said they rarely replace them because they're so durable.
And at $15 each, I'm not sure I'd do it again. The old ones were in good shape.
By the way, my manual recommends removing the radiator and getting at the plugs from underneath. Not sure I'd do that. I happened to have the tank off and got them from above and it was hard enough to get the direct-fire coils out of the holes.
I have an 06 with the Irridium fine-wire plugs. Earlier models used another plug, I believe.
--Paul
Old Mar 25, 2009 | 05:17 PM
well i got it stripped to the frame, engine and thats about it. about to drop the radiator to clean and make the valve job easier. i got 37k miles, plugs were changed at like 25k or somethin
Old Mar 26, 2009 | 11:38 AM
mnguyen84's Avatar
my service manual says every 16k. 8k is too often.. that doesn't make sense.
rapidspec
Jan 14, 2015 04:04 PM
MARCD1
Jan 9, 2012 09:49 PM
Stoner
Mar 20, 2011 08:15 PM
sixs929
Jun 1, 2006 06:51 PM
CivicRacerX7
Feb 13, 2005 02:08 PM
