Spark Plug always fouling
what kind of MPG are you getting? Below 30 MPG is a hint that the FPR has a problem. Next is to prop up the tank and pull the vacuum line off it. If its wet with gas, then that's another strong hint.
The full diagnostic involves using a fuel pressure gauge but most people never go that far.
Still problematic..
Finally, the FPR and o-ring I ordered came and I was able to replace them in my bike.
I also replaced the spark plugs and synched the throttle body with a Morgan Carbtune.
It worked very well for a week, and then the plugs got fouled up again.
I opened it up and found the #4 plug is wet with fuel.
I replaced it and the bike went smooth again.
After another one and a half week, all plugs were fouled up. I havent opened it up but i'm guessing they are soaked in fuel again.
What else could be the problem?
Did I miss anything?
Another thing - when I did the synch, all valves were level at 1.3K RPM. but when i turn off the engine, it turns out the idle is too low that i cant even restart the engine. i would do this again and again, same thing. until i just settled for a 1.4k rpm (that doesnt change even if i switch the engine on and off) but the catch is not all four valves are equal. only #1 and #4 is level with each other, as well as #2 and #3 together.
What else can I do?
What else can I do?
