Spark Plug always fouling
Hi Guys,
I'm hoping someone here would be able to help me out. My 2002 F4i sounds like a helicopter again for the 4th time now. I notice that after having a long ride (100+ km), this happens. The good thing is, after changing the spark plugs, it goes back to it's smooth riding again. But I have changed the plugs so many times that it has become costly already. I have cleaned the injectors and done the throttle valve sync but the plugs keep on fouling up. Do you have any idea how I can solve this permanently? Thanks in advance.. |
how is it fouling out
oil gas water got a pic of one? |
The plugs are burnt dark brown but not all 4 are equally discolored. 1 and 3 are more dark. It seems fuel is the more likely culprit but i dont know where it's coming from or how it does.
Sorry I dont have a pic yet, I might open it up on the weekend though.. |
dose it look like any of these?
http://www.gnttype.org/techarea/engine/plugs.html |
it most likely looks like the illustration on Z-3 or the Carbon Fouling.. I sometimes encounter problem on cranking the engine. I figured it's a low battery charge but one moment its ok, the next its dead, then ok, then dead.
I rode the bike yesterday for around 60kms and i was able to rev it upto 8k RPM. I was thinking I could scare the carbon deposits away. I hope this was not a stupid thing i did... The bike had power but not comparable as before. today it's running, and still doesnt sound like a bike. |
have u checked your fpr yet?
sorry for my ignorance, what's fpr?
fuel pressure regulator. You can get one for $60 and have it changed out in 45 minutes tops. If you have a power commander it could have a map on it thats making your bike run really rich.
Originally Posted by mugball
(Post 945347)
it cranks and starts up. problem is, not all the plugs are firing and for those that do are only 35% efficient. the misfire makes the bike sound like a helicopter!
how do i check the FPR if its working well or not? does it include the fuel pump, coz i have replaced that before. |
