SLIP-ON + K&N Filter= Power commander?
Old Mar 22, 2007 | 01:58 AM
gittinitup's Avatar
Default RE: SLIP-ON + K&N Filter= Power commander?
ORIGINAL: almost_there6
I'm not worried about the valves. I put on the PC III and loaded up the closest map that i could find. Next week I will be dyno tuning my bike and making changes to the map that I am using now to even better suit my bike.
I was refering to air filter, slip on, no cat!(hurting bike)not all that plus a powercommander with there map
Old Mar 22, 2007 | 10:32 AM
xtremef4i's Avatar
Most all aftermarket pipes and air filters were designed to use with the factory mapping. The power commander just enhances it. You will be fine with out one but once you get it, you will be glad that you did
Old Mar 22, 2007 | 11:01 AM
Candymanmo06F4I's Avatar
So even if you have a slip on with factor air filter do you still need the pc III? Cause it seems like this is a yes or no question but always gets every response or is it up to the rider.
Old Mar 22, 2007 | 02:22 PM
christhek's Avatar
K&N Filter and M4 Slip on w/o power commander for 2 years and no problems. It is not needed, it will only enhance or fine tune what you have.
Old Mar 22, 2007 | 02:28 PM
Ruftags's Avatar
No, I road mine for 2 summers with no probs with just a 2 bro slip on. The only advise I have is let bike warm up to over 140 before gettin it it, or you have a good chance of foulin plugs. I put K/N and PCIII on this winter and have only riden it twice with the map from PC. Need to get tuned. But you will be OK with just a slip on.
Old Mar 22, 2007 | 02:48 PM
Tahoe SC's Avatar
toss the K&N it's POS...
don't worry about burning valves, etc...it's not going to happen.
you will be fine, but the bike just won't perform as well or may not be as smooth. it's like this...if you want everything to be working good, so you get the max performance for your parts...but if not it's no big deal.
Old Mar 22, 2007 | 03:22 PM
younghutch's Avatar
Get the PCIII anyway. Eeven without any other mods you will notice a big difference in throttle smoothness & response. Cooler running also by about 4-5 deg.
Old Mar 22, 2007 | 09:13 PM
Italio13's Avatar
I will end up getting a PC3 but not this year thanks for the info
Old Mar 23, 2007 | 12:52 AM
Brandon77's Avatar
Im in the same situation..muzzy slip on w/ K&N, but im in no hurry to get a PCIII, eventually though. Not to worried about it, it runs fine.
NateDieselF4i
Jun 9, 2010 09:55 PM
eee4666
Dec 31, 2007 07:10 PM
klutch_r
Oct 31, 2007 03:00 AM
sc929
Sep 13, 2007 12:32 PM
Mpolitan0
Mar 23, 2007 10:37 AM
