shim the rear or lower the front?
Old Mar 14, 2007 | 05:28 PM
ninetyfivehp's Avatar
Default shim the rear or lower the front?
is it possible toshim the rear without unloading the suspension or can i just lower the front maybe 5mm to quicken the steering on my 06'. i don't want to run into any ground clearance issues. i was thinking 5mm in the front won't have me deckin the can. thanks
Old Mar 14, 2007 | 07:44 PM
Tahoe SC's Avatar
Default RE: shim the rear or lower the front?
it would be faster to lower the front a bit...but for the rear, you can actually just add a washer to the top bolt of the shock mount to raise it up a little bit.
Old Mar 14, 2007 | 07:48 PM
thanks Tahoe, but i have no way to support the rear off the bike to unload the suspension. i only have aswingarm stand and no way to support it from the ceiling of the garage?
Old Mar 14, 2007 | 07:49 PM
if i lower the front, how many mm would you suggest raising the forks?
Old Mar 14, 2007 | 08:12 PM
Tahoe SC's Avatar
you should unweight the front too if you're unbolting the forks...makes sure everything is straight...do you have a front stand?
i say keep the front, raise the rear. use jackstands to unload the rear via your rearsets.
Old Mar 14, 2007 | 08:21 PM
no, i was just gonna loosen the pinch bolts enough that i could swivel the fork tubes up by hand. not a good idea
Old Mar 14, 2007 | 08:23 PM
also my rearsets are stock so they fold[&:]
Old Mar 15, 2007 | 04:14 AM
Tahoe SC's Avatar
the pegs fold, the rearsets don't...time to get creative!
drop the front just a few mm to see how you like it.
too much and you'll feel it in the turns...won't be very stable and will feel like it wants to slide out.
madman
Jun 27, 2011 04:53 PM
my_honda
Oct 19, 2008 09:54 PM
Rated R
Aug 31, 2007 02:34 PM
BoostinFD
Sep 30, 2005 09:11 PM
