running rich?
RE: running rich?
slip-on really shouldnt change much, now if it was a full exhaust that might be a different story. it is possible that the bikes computer recognized that there was a better exhaust airflow so it started giving the motor more gas. im sure the computer should reset itself after awhile. if not then remove the battery to reset the computer. and if all else fails and you still think something is wrong then take it to your dealer.
RE: running rich?
ORIGINAL: SquireSCA
The F4i does not sense a change in flow or adjust anything.
All that I can think of would be that his bike has an O2 sensor and the new pipe does not use it and so the mixture is off.
