Running rich
Old Jul 31, 2008 | 05:23 PM
DBEAU's Avatar
Default Running rich
My bike runs very rich. It has a slip on but no filter, if i install a aftermarket filter will it lean it out a little bit?
Old Jul 31, 2008 | 05:59 PM
wannaride's Avatar
Default RE: Running rich
Sorry, I dont have an answer for you but my 01 seems to run a little rich too.. all i have is a slip on. I would have thought the slip on would make it run a little lean if anything. ????
Old Jul 31, 2008 | 06:29 PM
01f4irdr's Avatar
how rich? bad gas mileage? any performance loss?
Old Jul 31, 2008 | 07:01 PM
DBEAU's Avatar
gas mileage is pretty average, performance is great like always. it just stinks of gas
Old Jul 31, 2008 | 11:19 PM
whtan20's Avatar
Same symptoms and problems I have, also sometimes it sounds l-i-k-e it's backfiring.
Old Aug 1, 2008 | 08:56 AM
DBEAU's Avatar
no backfiring here
Old Aug 1, 2008 | 03:34 PM
DBEAU's Avatar
Anyone...
Old Aug 1, 2008 | 07:26 PM
01f4irdr's Avatar
when my 01 f4i was running rich it turned out to be the fuel pressure regulator. but i was getting awful gasmileage and it reeked of gas. i would also check spark plugs. an aftermarket air filter isnt gonna change much
Old Aug 1, 2008 | 07:57 PM
Xuracing's Avatar
I have an 01 running rich for some reason too. it has Full exhaust PC3 with the right fuel map from dynojet. I actually backfire and shoot flames :-/
Old Aug 3, 2008 | 09:59 AM
BigNate354's Avatar
i have an 01 and mine is running rich, getting horrible gas mileage like 70 miles to a tank, should i replace the fuel pressure regulator and if so how much did it cost u, i just replaced my sprockets to 1 down in the front and 4 up in the back i dont know if maybe that is causing my gas mileage to go down
