reserve fuel light problem
Old Aug 18, 2008 | 11:12 PM
reaper75032's Avatar
Default reserve fuel light problem
when i had my bike painted.. i took the tank off, drained it and everything worked fine when i took it off.
now since it has been painted , the reserve fuel bars ( 4 little bars) constantly flash. i have tried removing the postive battery cable.. unplugging the fuel pump. and even removed the fuel pump and cleaned it up with the same response.. when i take the battery off or unplug it ,, the reserve goes out for a few minutes then comes back on and runs down till all 4 bars are flashing and stays that way. and when it was painted the fuel pump was not removed from the tank..
any clue as to why or what to do?
Old Aug 20, 2008 | 11:48 AM
CBR Time's Avatar
Default RE: reserve fuel light problem
hmmm, not sure about that one? bump for ya though
Old Aug 20, 2008 | 12:03 PM
Xuracing's Avatar
maybe the intake sensor is stuck at the bottom position. How long was the tank off? could have caused everything to dry out and stick. Check out the assembly in the tank
Old Aug 26, 2008 | 10:03 PM
LiMe_GrEeN_MaChInE's Avatar
im also having this problem, the res, and 4 bars are always flashing weather it is empty or totally full so idk, any help guys?
Old Aug 27, 2008 | 06:04 PM
the tank was off for about 3 weeks.. and when it started i took the fuel pump out.. cleaned it out real good. tapped on everythin just in case it was stuck. put it all back in with the same results.. looks like im just going to have to get a new fuel sender assembly IDK
Kevin48
Oct 21, 2008 04:23 PM
CelerityBikeRyde
Sep 23, 2008 08:56 AM
stabZ
Jul 13, 2008 08:25 PM
civiksi
Oct 24, 2007 06:24 PM
Clint Z
May 17, 2006 12:46 AM
