Burned taillight bulb AGAIN
I just replaced my taillight bulbs (both) less than 2 weeks ago. Yesterday I noticed that the left has burned out again. What's possibly causing my tail bulbs to burn out?
No other electrical is going out.
No fuses are burned
I have a spare bulb and will put that in, but I would like to find the underlying cause.
Suggestions?
No fuses are burned
Suggestions?
RE: Burned taillight bulb AGAIN
Check to see no water is getting into your tail light. Check the condition of your connectors to the tail light. Check voltage to the rear tail lights to make sure its where its supposed to be and not to high.
Then apply dielectric grease to the connector and hope for the best. Theres really no reason why bulbs blown out or don't blow out. My rsx has 143k miles and just last yr i replaced 2rear brake lights but the other too are still original.
Same problem here, I'm guessing its just cheap sh!tty bulbs. One burned out last year so I went to the local Honda dealer and got a new one. Installed it in the parking lot and when I turned the key it instantly went POOF!! I talked to the lead mechanic and he said it was a bad bulbunless thereis a short in the wiring, which is highly doubtful. Went back in and bought another one (they wouldn't replacethe one I just bought forfree) and that one worked fine. Now my otherbulb is out.
thanks, ill have too keep that in mind. I was told a 15 wouldnt hurt instead of a 10 cuz my fuse kept blowin with my high beams on. Actually, does anyone have an idea why my headlight fuse blows if i start my bike with the highbeams on? i put a 15 amp fuse in it and it stoped doing it.....any thoughts on that? [sm=feedback.gif]
ORIGINAL: movi cbr
Is it a stock tail light? If the fuse is to strong, it might be sending too much power to the bulb. You could try dropping the fuse size. I had to raise my fuse size for my headlight because the bulb was a higher watt and kept blowin the fuse.
Regardless, there is another problem causing it. Either an electrical short, crappy bulbs, etc.
One thing you should not do is touch the bulb with your bare hands. The oils from your skin heat up and hurt the integrity of the bulb, thus shortening its life.
