Replace stator ?
Old Dec 8, 2007 | 01:28 PM
socalninja's Avatar
Default Replace stator ?
Well after the bike has been laid down twice on the left side (once by me once by previous owner) that stator cover is pretty scratched up. I got an OEM replacement on ebay for around $65 shipped with a gasket included. Has anyone that has done this before give me a run-down of what I need to do? I'm assuming I'll need to drain the oil first (so I can do it during my next oil change). Any hints or suggestions? thanks
Old Dec 8, 2007 | 02:51 PM
alekinci's Avatar
Default RE: Replace stator ?
its a simple process really. you dont have to drain all of the oil if you want to do it now and not wait til oil change. undo the bolts from old cover, take off old cover, take off the remains of old gasket. place the new gas gasket with cover on. before you bolt it down to the engine case make sure that the stator wire boot cover is not moving /loose. then bolt it down and then go stuntin!
Old Dec 8, 2007 | 03:45 PM
socalninja's Avatar
Hmm so that's it? I thought because of the gasket it would be holding oil in. So I don't even have to lay the bike on it's right side?
Old Dec 10, 2007 | 03:44 PM
socalninja's Avatar
OK, I found the information I needed, but all the websites refer to sealing the gasket with a silicone sealant. I have Permatex ultra black and ultra blue sealant. Is there a particular one I should use, or is it safe to use either one?
Old Dec 10, 2007 | 08:56 PM
alekinci's Avatar
i remember using just the first silicone sealant i fount in the auto store.
Old Dec 11, 2007 | 12:18 AM
socalninja's Avatar
thanks alek
Old Dec 11, 2007 | 09:54 AM
BoRkA's Avatar
you need a gasket sealant?
I simply took off old cover, scraped off the old gasket, put on a new gasket on the new cover and bolted it back.
Did i miss something?
Old Dec 11, 2007 | 03:23 PM
alekinci's Avatar
^nope, you did not miss anything.
socal, i should have mentioned that the sealant that i grabbed was an all purpose silicone(which listed gasket use).
good luck bud and remember about the wiring boot. try to allign the cover with the engine block so the boot does not move about.
Old Jan 10, 2008 | 10:05 PM
tollfree969's Avatar
Is it okay to just use liquid gasket sealer or should I buy a gasket? Also, should I use the sealer on the grommet that seals the wire in the stator cover or is it okay to just push it in? Thanks
Sanders Justin
Aug 1, 2013 12:52 PM
Nauree
Sep 9, 2008 12:00 PM
slutty62cont
Aug 14, 2005 01:06 PM
