Removing rear wheel?
RE: Removing rear wheel?
Should be the same as your R1. Get it up on the swingarm stand, use a wrench on the left side (axel) and throw a wrench on the right side (nut) and turn like a **** because it should be torqued to 69 ft lbs, usually a bear to break loose. Slide out the axel to the left, also a bear to pull out, support the wheel before hand too. Once the axel is out the wheel should drop right out. Also the sprocket assy will fall out too once the wheel's off and don't lose any of the rubber cushions inside the sprocket assy.
