Recommended oil
Old Aug 15, 2009 | 09:53 AM
Uniqsol's Avatar
Originally Posted by K7inne09
Why no Fram cageless? Also I run Mobil-1 AND Fram both of which apparently suck according to you guys lol looks like ill have to make some changes....Ive grinded and missed a few gears before or it hasnt gone into gear right away...New rider problem or ****ty oil problem?
Do it on the cheap (but good quality). Use the Supertech (Walmart) filter ST7317 (It's made by Champion), and Rotella-T 5w40 full syn. (in the Blue Jug).
That filter is cheap (~$3) and it is the the same quality as OEM...plus it is a bit taller so it will filter just as good, if not better that OEM.
Old Aug 17, 2009 | 07:50 PM
R Dub's Avatar
October 2011 ROTM
So I decided to go with Amsoil and Jesus was it expensive. Cost me $71 for a oil change. I don't even spend that kind of money on my girlfriend. However I instantly noticed a difference, she shifts a lot smoother. Still not perfect but a world better.
Old Aug 17, 2009 | 10:34 PM
DonF4i's Avatar
??? DAMN ??? Its not even that much for my car!!! (Amsoil)
Old Aug 18, 2009 | 01:34 AM
F4ith's Avatar
Originally Posted by ali7up
i ran mobile 1 4t 10w-40 and it was smooth for the fist 100 or so miles after that same problem
Same problem with mobil 1. Now I'm just debating between Amsoil or Rotella...
Old Aug 18, 2009 | 01:38 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Well, how much do you want to spend? $71 or $25 ...
Old Aug 18, 2009 | 09:28 AM
JasondanGraham's Avatar
Default rotella t
I am thinking of going to rotella t but Im kinda nervious about using because it is a diesil oil. Does anyone have any feed back on this oil. what is the long term effect of this oil? Thanks
Old Aug 18, 2009 | 02:13 PM
Incognito's Avatar
It's heavy duty motor oil. There's no such thing as diesel oil, or gasoline oil for that matter.
Check out what these guys think: Bob is the Oil Guy Forums.
Old Aug 18, 2009 | 11:39 PM
purpleslug's Avatar
i started using castrol and started to miss shift like a mother F-er and now its slipping in 3rd doing clutch ups
Old Aug 19, 2009 | 07:15 AM
Default rotella
my computer is not alowing me to open bobs forums. So is this an oil you would recomend or what kind of oil would you recomend. THe only oil that is out of the picture for me is amsoil not because its not good but because its 19.99 a quart at thr local store.
Old Aug 19, 2009 | 09:37 AM
Uniqsol's Avatar
Here is another Oil Info page... VERY informative. And they recommend Rotella-T 5w-40 in the blue jugs. Motorcycle Oil and Filter info
