Quick Fuel Filter Replacement Questions
Old 08-08-2007 | 08:36 PM
ampfp's Avatar
Default Quick Fuel Filter Replacement Questions
I couldnt find a how to so had some quick questions:
1> Do I need washers to change the filter? (I need to do it before a weekend ride so cant wait for parts ). The only place where the manual mentioned a washer was while relieving the fuel pressure with a screw.... cant I just wait an hour or so for the pressure to disappear after switching off?
2> Do I need to clip any fuel lines while turning the tank upside down? How to avoid getting fuel all over the place?
Thanks...
Old 08-09-2007 | 10:36 AM
Tahoe SC's Avatar
Default RE: Quick Fuel Filter Replacement Questions
technically you do not have to remove the any of the gas lines when doing this, but you will need a new gasket, the one that holds the pump to the bottom of the tank. reusing will cause it to leak. to remove the fuel filter all you need is a wrench and some patience. it's just some clips (like the ones used for the radiator lines) holding the filter in place.
Old 08-09-2007 | 12:11 PM
ampfp's Avatar
K thanks... I'll try to get the gasket... the shop should recommend it everytime someone gets a filter...
I thought I'd have to turn the tank over to avoid the fuel inside from spilling when I took off the pump... which would mean removing the hoses...?
grumps91gt
10-03-2009 09:04 PM
jacked600
06-16-2009 12:13 AM
slingy
01-22-2008 10:47 PM
CBRrider01
11-06-2007 10:51 PM
usndocjaysin
09-21-2007 11:18 AM
