Quick frame slider question
Old 04-18-2008, 06:03 PM
jkh421's Avatar
Default Quick frame slider question
The only hole cutting bits i can find all say the are for wood or metal, Will that be ok for cutting out my slider holes?
Old 04-18-2008, 07:03 PM
jaynd's Avatar
Default RE: Quick frame slider question
yep, just go somewhat slow and you'll be A-ok!
Old 04-18-2008, 07:29 PM
jkh421's Avatar
Thank you
Old 04-18-2008, 07:37 PM
jaynd's Avatar
no prob! what method are you using.....silly putty or laser?
Old 04-18-2008, 09:17 PM
FFCBRf4i's Avatar
You're cutting plastic, so it's fine.
Old 04-18-2008, 11:46 PM
Plastic = Wood! I engineer cutting abrasives and materials for a living. Buy a wood cutting set and drill away, you will be fine. Carbide/HSS > plastic
Old 04-20-2008, 03:43 AM
Joe Rocket's Avatar
Cover your fender with some masking tape to help prevent flaking. And like everyone says, take it slow...
Old 04-20-2008, 03:51 PM
jkh421's Avatar
I actually used a paint marker and marked the end of the bolts it worked excellent my cut was dead nuts ill post some pics when i feel like walkin outside and takin em it is hot out right now
Old 04-20-2008, 04:13 PM
jkh421's Avatar
Here it is Paint marker worked pretty well
[IMG]local://upfiles/18965/F034D6D9D3654179A67141E418422385.jpg[/IMG]
Falqon
How-To: Mechanical
20
09-30-2010 10:01 AM
tingaling
07-09-2009 04:29 PM
Tacoma747
01-09-2009 01:50 PM
motonewbie
03-28-2007 03:51 AM
MaxKid84
09-18-2006 12:18 AM
Quick Reply: Quick frame slider question
