quick frame slider question
Old Aug 29, 2006 | 04:21 PM
MaxKid84's Avatar
Default quick frame slider question
I'm looking to make some frame sliders at work to help protect . . . well the frame sense I don't have fairings.
I want to make two little ones for the end of the grips, and two larger ones to bolt to the frame.
I'm thinking of the two locations I circled below to mount the larger ones, which location would you guys recommend, I'm thinking the upper one.
But I definitely want to protect the covers cause they are in near perfect condition as is, so maybe I'll do both.
Also, can I replace this bolt with a slightly longer one with out any problems (the sliders will be counter bored), I see that it helps mount the engine to the frame, I don't want the thing dropping out on me.
any suggestions or insight would be helpful, thanks!
Old Aug 29, 2006 | 07:03 PM
SIRR1's Avatar
Default RE: quick frame slider question
Yes you can replace the bolt with a longer unit to fit your sliders.
Either location on the frame looks like a winner.
Another location would be on both sides of the rear axle.
If you are replacing nuts and bolts as a unit on your bike keep it metric and try not mix and match SAE and Metric bolt and nut combos.
Old Sep 10, 2006 | 07:42 PM
Detroit Cane's Avatar
what year tail section is that and how did you get it to fit?
Old Sep 11, 2006 | 01:27 AM
rrasco's Avatar
ORIGINAL: Detroit Cane
has to be 03-04 since the key lock is not visible between the two seats, but if i remember correctly, he bought it that way. i am doing the same mod to my bike which you can read all about here.
Old Sep 18, 2006 | 12:18 AM
yo thanks ras. Iwanted to do the same thing to my f1. Also, does that compromise putin a rider on the back seat.
Falqon
How-To: Mechanical
20
Sep 30, 2010 10:01 AM
tingaling
Jul 9, 2009 04:29 PM
Tacoma747
Jan 9, 2009 01:50 PM
jkh421
Apr 20, 2008 04:13 PM
motonewbie
Mar 28, 2007 03:51 AM
