Quick Flushmount Help- Wiring stuff...
Old Jul 21, 2006 | 03:15 PM
05F4iGuy's Avatar
Default Quick Flushmount Help- Wiring stuff...
Here is what they claim to do (dealer)
"Once the mid fairing is off you splice the two wire on our LED's its black and red. the black goes to green on both sides. then the red wire goes to the orange wire for the left signal and for the right it goes to the light blue. "
What if I just spliced the two OEM wires (blinker/running) together on the hot wire of the flushmount.??? With the instructions I got provided it will only work one or the other. Plus both the wires are the same color one just has a stripe on it.. got I hate ****ty instructions....
Old Jul 21, 2006 | 03:32 PM
05F4iGuy's Avatar
Default RE: Quick Flushmount Help- Wiring stuff...
Hmmm, looks like thems the breaks of looking good. So I think I confirmed that I will not be able to still have the running lights.. DAMNIT.
Old Jul 21, 2006 | 03:44 PM
Chamuko's Avatar
You will if they Are LED. Soo one of those positive wires is constant on the other is the blinker signal.
Old Jul 21, 2006 | 04:08 PM
jjkukla's Avatar
Learn to use the "Search" feature buddy, it helps a TON... and your question woulda been answered before you asked!!!
https://cbrforum.com/m_129799/tm.htm
You can also download a service manual (use the search feature once more) and it will show you what wires are constant, signal, ground, etc.
Old Jul 21, 2006 | 07:14 PM
BigWill's Avatar
You can use them as running lights and blinkers. Its just makes your dash blinker stay on (it still blinks). Thats how I have mine setup, both the running and blinking hooked up and it works just fine.
Old Jul 21, 2006 | 08:54 PM
Diabo's Avatar
Here's a question for you, did you purchase a single filiment flush mount or a dual filiment flush mount.
The single filiment has 2 wires and only works as a blinker
The dual filiment has 3 wires and works as a blinker and runnng lights.
Diabo
Old Jul 21, 2006 | 11:47 PM
05F4iGuy's Avatar
They are the hotbodies two wire set-up.. I think I am just going to add a second set of running lights in the air ducts with blinkers/running lights- 3 wire setup.
Old Jul 22, 2006 | 12:28 AM
Diabo's Avatar
See if you can exchange them for the dual filiment ones. I made the same mistake and my new short stalk blinker/running lights should be in Monday.
Good luck
Diabo
cooltim
Jul 31, 2011 07:55 PM
lino129
Nov 6, 2009 10:19 AM
jmiller427
Feb 23, 2009 03:07 AM
Nobble
Jul 23, 2007 06:12 PM
ciupe
Mar 17, 2006 10:53 AM
