THE question
Old May 11, 2007 | 01:12 AM
f4iguy8804's Avatar
Default THE question
I have that rattling noise that I hear so much about. CCT. I have done some research and still can't decide which replacement to use- the APE manual tensioner or the Honda OEM hydraulic. I am torn between the two because I don't have the mechanical expertise. Pleae shed some light on this.
Old May 11, 2007 | 01:21 AM
voodoochyl's Avatar
Retired Moderator
Default RE: THE question
...Tahoe, were are you, Bro?
Old May 11, 2007 | 02:46 AM
ampfp's Avatar
You can fix it with a simple bolt and nut. Look in the How To section for cct. Someone has posted how to install APE, and someone has replied with a $5 fix, which was recommended by a honda tech to him.
Old May 11, 2007 | 03:06 AM
Stephens's Avatar
yah, there is a post on how to install it, in the How to forum.
Old May 14, 2007 | 12:47 AM
f4iguy8804's Avatar
Has anyone out there tried the 5 dolla fix?
Old May 14, 2007 | 01:08 PM
jjbtao's Avatar
I tried the nut and bolt fix and it didn't change it a bit... Ended up doing the other fix--(the one done by expanding the small roll pin at the tip) and it reduced the noise significantly. That's my $.02
Old May 14, 2007 | 01:53 PM
Tahoe SC's Avatar
i don't do cctl posts anymore...
there's more than enough information floating out there for a monkey to make a decision...
not an attack on the OP...just that i feel that mokeys > humangs.
if you don't have mechanical expertise, then go with OEM.
the difference between the 2 is APE...you manually adjust it yourself until you get the right tension...as it consists of one of the world's most expensive bolt and lock nut combination next to what NASA uses.
OEM...made up of 2 many parts that get worn and make noises...rattling, headache, etc...but uses a spring that automatically extends the cctl pin to get the proper tension...
tada! done!
Old May 14, 2007 | 02:26 PM
camaro68's Avatar
Is this a real problem if you have the rattling or is it just one of those annoying things?
Old May 14, 2007 | 02:36 PM
Tahoe SC's Avatar
it's one of those annoying things...like cctl questions! muhhahahah...
however, if you don't take care of it...it WILL drive you mad...seriously...
starts with a bit of rattling, etc...then it gets bad...like REALLY REALLY loud...
eventually you'll be forced to replace it cause everyone will be looking at you and laughing!
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
