Project: F4/F4I Track Bike
Old Nov 20, 2013 | 05:12 PM
Diesel7926's Avatar
Originally Posted by RudyGT
well, like i said, when you get to the edge of the tire, or close to it, you will scrape more than the rearsets.
another problem is with rearsets that are exactly like OEM like those woodcrafts, your linkage may hit if you decide to go even higher and run GP shift.
the best i found that are fully adjustable are chinese or prolink, i think
im pretty sure mine are higher than what the woodcrafts are, and are stock. i scraped the feelers at the track, so i removed them. i scraped the peg. my toe
and finally i scraped the stator cover, the bike is not tall enough! consider shimming it a little. depending on the year it should be as simple as putting a washer in.
just some heads up, nothing worse then going wide on a turn cause you are grinding your bike into the asphalt.
I appreciate your input, I believe I read somewhere about shimming the rear shock linkage where it bolts to the frame? is this correct?
Old Nov 20, 2013 | 06:29 PM
RudyGT's Avatar
i havent done it myself, but that is what i read. some models have more thread coming out of the top where it bolts to the frame and you put some washers in there.
but be comfortable with the bike. you will lose stability and possibly braking power.
im raising my rear end and then adding more preload to the front of mine. im thinking im sagging over 40mm in the front.
also i messed up the name of those rearsets its pro-tek, and after i seen a used pair on ebay sadly they look the same. i have a thread trying to sort this shift lever thing out...
edit:
https://cbrforum.com/forum/how-mecha...height-119408/
ianp5uk
Nov 2, 2011 09:06 AM
manumaman
Oct 17, 2006 08:45 PM
manumaman
Aug 26, 2006 01:21 PM
