problems with gettin the bike started
well i bought another f4i today .. bike started up when i picked it up put it in the back of my truck and brought it home .. got home took it out hooked it up 2 my truck (truck off) cranked up no problem .. my friend took the clamps off as soon as it started up and it kille .. after that i cant get the bike 2 start at all now .. i checked the fuses they are fine bike has gas the fuel pump turns on .. (ill be pullin the plugs tomm 2 see if they are good or not)
if anyone knows whats up pls help me out
I assume your killswitch is on because the fuel pump primes. If your kickstand is down it has to be in neutral. is the battery fully charged? Will it crank at all? Check your wires, maybe something came loose when you unloaded the bike.
u are reading it wrong ... and i got it started today i took all the plugs out cleaned them and plugged them back in and it started up .. the guy i got it from hadnt run it in 3-4 months its a stunt bike so no headlights
thanks for the help
thanks for the help
