getting the bike started.
Old Apr 29, 2008 | 05:47 PM
kappa's Avatar
Default getting the bike started.
alright everybody. im going to attempt to get this bad boy started.
give me some pointers.i have no previous motorcycle expirence. other and riding. what do i need to be looking for. ect.? help if ya can or im probably going to spend a **** load of money takin it to a mechanic. just the usuall things.
Old Apr 29, 2008 | 06:10 PM
tehehodi's Avatar
Default RE: getting the bike started.
take out the key, get on the phone, call your local dmv with motorcycle classes. Take the MSF course. , if you don't know how to start a bike, you should probably, high suggested, taking the class.
Old Apr 29, 2008 | 06:35 PM
kappa's Avatar
im talkin its not in running condition. sorry i didnt make it clear. but if you got that i was tryin to bring a old beast to life and was just being a smart *** f@#k off..
Old Apr 29, 2008 | 07:31 PM
2bikes's Avatar
Well I thought you were clueless too. Your original post sort of gave the impression that youdidn't havea clue and as strange as it may seem that there are people that clueless riding motorcycles, one trip to a MSF class will bring it home for you.
Now, on to the "what to look for". Give us something to work with. What was wrong with it? How long has it set? Was the bike complete when you bought it or in pieces? How does the oil look? What about the coolant level? Air cleaner? Tires, chain and sprockets, fork seals, battery? We certainly can't give you pointers if we don't know what we are working with.
Old Apr 29, 2008 | 11:28 PM
89cane's Avatar
i would suggest cleaning the crap out of the carbs. then buying new plugs. how long has the bike been sitting? you may need to drain the fuel from the tank and get fresh. i might change the oil depending on how it looks i would but just one extra plug and take the wires off the plugs one at a time to see if all cylinders are sparking. that is just a general list off stuff you may need check alot of things let us know what the bike does when you try to crank it so we got an idea on what a problem might be.
Old Apr 29, 2008 | 11:34 PM
HurricaneRider's Avatar
I would recommend a manual they help alot. For your more hands on things, these bikes being old, they tend to have little problems here and there, and the book helps alot i got my today and it help me with cleaning my carbs. Got it off ebay for $5.50 with shipping. But if your into walking to the computer and back to the bike all day you can check out cbrextreme.com they have a downloadable manual.
Old May 1, 2008 | 10:40 PM
kappa's Avatar
alright everyone . i noticed alot of play in my rear shock. is there a aftermarket replacement. or do i go to the dealer. or just buy a used one. my fork seals are busted. would i be better off updating my forks wit a new bikes forks. or fixing the old ones. if so which ones are interchange able. let me know.
Old May 1, 2008 | 10:59 PM
michigan_313's Avatar
how much do you have to spend?
a used rear shock will be much cheaper than any new aftermarket shock. but maybe Hagon will be cheapest of the bunch. others are nitron, hyperpro, and ohlins to name a few.
fork seals are econonical but you should also change the fork bushings while you are at it. and maybe the springs if out of spec or if you feel the need buying stiffer springs to firm up the forks and emulators for better fork action. any honda fork setupwill pretty much bolt on as far as the steering tube goes but you will need a complete front end (rim, clamps, rotors, calipers, fender) and some bit of modding as none of the f1 stuff is interchangeable with later model years fork setups.
Old May 1, 2008 | 11:10 PM
kappa's Avatar
yo man thanks for some help. thanks for the fast reply. if anyone else knows any info please help
Dazed
Apr 19, 2012 09:05 PM
j_wright20
Mar 9, 2010 11:34 AM
dusty4gov
Jul 15, 2008 03:05 PM
andrew
Dec 2, 2006 04:07 PM
BoardRider
Apr 21, 2006 09:09 AM
