The problem continues...
Old 06-26-2012, 03:00 PM
74demon's Avatar
87 gas
They look evenly rich. That means it's something affecting all the cylinders. Your FPR is new and good, you did take out the plug before putting it on, right? The return fuel line plugged up or kinked? Coolant temp sensor? Test it...measure resistance across the sensor. 2.3-2.6k ohms at 68 deg. resistance should change with temp.
  #22
Old 06-26-2012, 03:22 PM
mcmuscle's Avatar
FPR is not new, however I checked it by blowing through it (which I coudn't) and The vacume line didnt have any fuel in it. THe coolant temp sensor? where is that located? and Im pretty sure none of my fuel lines are kinked or leaking. I rode it some today, It runs super weak!! I think 1 or two of the cylinders aren't firing. Im pretty sure the a few of the plugs aren't working. (im pretty sure these are the stock plugs with 12,700 miles in it. I bet the original owner didn't change them)
  #23
Old 06-26-2012, 03:35 PM
74demon's Avatar
Coolant sensor is on the thermostat housing. Does it run rough? Or just no power?
  #24
Old 06-26-2012, 04:59 PM
mcmuscle's Avatar
it sounds sorta normal at idle, but when the rpm's go up it sounds funny (like a v-twin).. And going down the road it has no power, I have to get the rpm's up to like 4k just to pull out without it dying.
  #25
Old 06-26-2012, 05:22 PM
74demon's Avatar
Replace the plugs, or clean them, and see if things change. It kinda sounds like it's misfiring, but it's hard to tell because of the high idle. It may just sound like that because the plugs are all fouled out.
  #26
Old 06-26-2012, 08:31 PM
mcmuscle's Avatar
alright, any recomendations for cleaning the plugs? gas? seafoam? little bit of 800 sand paper?
hawkwind
12-16-2011 07:49 AM
JankCibberf2
F2 Tech
10-09-2011 02:26 PM
switched
F2 Tech
04-06-2011 12:32 AM
snowboarding82
05-22-2008 08:08 AM
KidCr3nshaw
06-07-2007 01:38 PM
Quick Reply: The problem continues...
