problem with bike starting.....HELP!!!
Old Feb 8, 2008 | 08:07 PM
slvr600's Avatar
Default problem with bike starting.....HELP!!!
Had the bike apart for the winter to rebuild, went to put everything back together fuel pump wont turn on.....then when i went to try it again today...all i get is clicking noise from a relay by the battery...any help? The battery has charge so....im clueless!!!!! I have a 600 f4i 2002! any help would be much apreciated.
Old Feb 8, 2008 | 11:10 PM
Stephens's Avatar
Default RE: problem with bike starting.....HELP!!!
Maybe you blew a fuse?
Old Feb 9, 2008 | 02:49 PM
f4ez's Avatar
i just had mine torn apart for split seat converion (06 f4i) and when i got it all put back together it just sat there and turned and turned but it wouldnt start and it turned out that i had tooken a fuse out that i assumed went to my fuel pump and when i reinserted it it fired right up...it was a 30amp fuse the green one and it was located right next to the battery...good luck
Old Feb 10, 2008 | 01:14 PM
charlos's Avatar
yup check the fusebox specifically the fuel pump fuse and the bank angle sense fuse. the clicking is the giveaway.
Old Feb 10, 2008 | 01:19 PM
devlzluv's Avatar
ya i agree with them also make sure u have everything hooked up, prolly something easy just keep us updated
Old Feb 10, 2008 | 04:22 PM
Bullswool's Avatar
Sounds like fuel pump didn't prime and you continued to crank it hoping it would start. Clicking sound is coming from starter motor cuz the battery has insufficient charge to engage the bendix throw out thingy. Charge battery and make sure angle sensor is hooked up.
My two coins.
Old Feb 10, 2008 | 06:11 PM
f4ez's Avatar
yea on my buddys bike his battery wasnt throwin 12.2 amps so it would just sit there and click
Elw00t
Aug 31, 2013 06:01 AM
marcusa
Nov 26, 2009 01:34 AM
meeson01
Oct 4, 2008 06:04 PM
silentimpact
Mar 10, 2008 10:50 PM
hot_rocket_rider
Jul 30, 2005 01:06 AM
