Probably a dumb question but... (fairing related)
Are all f4i fairings the same? I keep seeing 01-03 and 04-06 but they look very similar. I have a wrecked 02 that I am needing to fix and would like to know what all is compatible (need headlight, fairing stay, cluster, right fairing, upper, and V)
Thanks
Thanks
the upper, left, right, lower V, gas tank, and headlights are the same. the tail section is the only difference between the two.
fwiw, I have a left fairing and headlight assembly for sale
AFAIK the cluster is the same, no reason for it to be different.
here is the headlight,
https://cbrforum.com/m_353378/tm.htm
I'm looking for a new fairing kit for the 2004 F4i. Will everything except the tail section from an 01-03 work for the 04-05? The Honda dealer tells me the parts are different. I know the tail sections are different, but I'd like to put a 2 piece seat on it anyway.
Thanks
Thanks
You're going to need more than just the tail fairing and seats to do the split-seat conversion though.
ORIGINAL: krash
