Power commander tweaks
Just got a good deal on a power commander on ebay. I have a yoshi slip on so uploaded the map for that until i have the time to dyno it and find a motorcycle or engine dyno. I have been playing with it a bit and looks like there are some more advanced features. What are common tweaks and things to play with? Does the ecu/pc3 allow any data logging to perhaps street tune the bike? Ive used motec a bit and magnet marelli and would be nice to be able to use a llamda function if thats available however realize this is not a multi thousand dollar system like those are.
Also thinking that the throttle position allowed me to rescale the throttle operation so that 100 percent could be reached quicker i changed the max value and do not remember what the factory max value is. I set it back to 27500 i believe but wanted to check to see if this was correct.
I have been talking with our local moto shop here that does dyno's etc. If you have a shop dyno it and set it up to your bike it would be the best setting you could get, better than any downloadable map. I have the 08 1000 with the dam 5 grand power band crap that they are going to delete the ecm stock settings and it will open it up and remove the 5 grand powerband ( makes it race ready ). That is going to run me $400, then i still need to add the power commander and have them dyno it for best performace ( commander $400/ dyno and recalibrate $260 ), I can't wait to get it all done.
maxwell139
05-16-2006 01:30 AM
