Pink wire voltage 2003 Honda f4i
Can someone please let me know your test results on the pink ignition wire? Mine test at 9.75v with the key turned on. As soon as I cut the engine stop run switch to the on position the voltage jumps up to 11.65v. is this normal for your good running bike? My fuel pump is not priming wanting to see if the voltage on the pink wire is the issue.
Thanks
Thanks
