PC3 commander
Old Jan 11, 2006 | 11:38 PM
missile's Avatar
Default PC3 commander
I know this has been asked but I am curious if anyone has used a power commander 3 usb lately and what kind of diffrents have you seen. I have a yosh. race pipe and a k&n filter.
Old Jan 12, 2006 | 10:36 AM
ampakes's Avatar
Default RE: PC3 commander
I got the same set-up as you. I have not done a custom map yet tho, just one from power commanders website. To be honest, I didnt see much of a diff. The one reason why I really bought it was to be sure that my motor wasnt running too lean or rich with my pipe and filter. Hope this helps.
Old Jan 13, 2006 | 12:57 AM
missile's Avatar
Thanks I'm still in limbo as to purchase one or not. I dropped one down on the front and was not happy with the higher revs. I only did it to help wheeling and then found out how to with the stock set up. If anyone has any other advice about the PC 3 I wold appreciate it.
Old Jan 13, 2006 | 09:52 AM
3power's Avatar
The PC3 really helps to smooth out the Air/Fuel ratio throughout the entire rev range, if you use the correct map. Most bikes have lean spots from the factory to help them pass emmissions tests, so you will even see a benefit if you retune the map with a stock pipe installed. However, if you're bike is running well there is probably no need to install one.
Old Jan 16, 2006 | 03:26 PM
Fox's Avatar
Fox
ORIGINAL: ampakes
Does DynoJet have a map for the Yoshimura RS-3 with a K&N air filter? I didn't see one on their website. If you have it, can you post it or link the page?
Old Jan 23, 2006 | 10:11 PM
mandosgreat's Avatar
Here you go:
http://www.powercommander.com/maps/0...0/m108-014.exe
This was found here, where all the other maps are. Enjoy
http://www.powercommander.com/108-211.shtml
joe-4422
Apr 7, 2009 09:47 AM
andref321
Jun 5, 2006 12:01 PM
maxwell139
May 16, 2006 01:30 AM
CMHGUY
Apr 7, 2006 05:32 PM
