Painting Windshield
Old Aug 20, 2008 | 02:43 AM
benjiaka's Avatar
Default Painting Windshield
Well, i read up on here previously, so i went out, and i couldn't find paint specificly for plastics, only bumpers for cars etc. Then i found some Clear Primer, for Plastics. I purchased that, and i've done two layers so far. I've got the black paint also, found for plastics (after searching hard) and it seems the primer, is slightly cracking? :/ will the black just cover it up? im going to do the certain section again with primer, but its stressing me out!
Old Aug 20, 2008 | 11:23 AM
Starleak's Avatar
Default RE: Painting Windshield
Well, you want to paint the underside of the windshield. If you primered it, then you kinda messed up already. Unless it truly is clear. Cause the primer is what you are going to see no matter what you put on next. If it really is super clear, then it may come out ok still. UNLESS you painted the topside, which aint gonna look very good either.
I did mine with paint from Orchard. It's for plastics only, and needs no primer and/or clear. It's a Rust-Oleum paint. Then says Specialty Plastic. Then on side says Direct-to-plastic paint. No Primer Needed, etc. Mine came out great. Looks really clean. I only did one coat, just enough paint to keep from seeing through it
Old Aug 20, 2008 | 11:34 AM
SjT's Avatar
SjT
I used this translucent model paint... http://www.hobbylinc.com/htm/tes/tes2949.htm
cheap and looks great. It runs easliy though so, you need to be very careful when you apply it.
Old Aug 20, 2008 | 01:26 PM
808HondaLife's Avatar
I just used glossy black spray paint I had lying around. It looks good enough until I buy a double bubble.
Old Aug 21, 2008 | 02:09 PM
jesterf41's Avatar
should have used krylon fusion paint. its made for plastic. no primer needed and paint the inside of windscreen and looks like u bought it that way.
Mac507
Apr 11, 2009 12:39 PM
OsinO
How-To: Mechanical
Apr 26, 2008 08:16 PM
amig
Feb 5, 2008 12:31 AM
Sammy Bono
Nov 23, 2006 01:42 AM
Keithcbr
Oct 26, 2006 04:42 PM
