Paint exhaust
Old May 29, 2010 | 05:01 PM
KdubyaH's Avatar
June 2011 ROTM
Lightbulb Paint exhaust
I was thinking about trying to paint my slip on. I know they sell heat resistant paint for headers. One of my concerns is Aluminum expands and contracts alot more under heat than steel and other metals.
I used to paint alot of aluminum parts when I worked at an Aerospace repair shop. We would just use Dupli Color High Heat out of a spray can and bake it off at 400 deg. So if it worked for turbine helicopter engine parts it should work for the bike.
Im going to take the piece I cut off and do trial and error. Ill keep you all posted.
Old May 29, 2010 | 05:34 PM
__Z__'s Avatar
April 2011 Ride of the Month
should work just fine using engine enamel because the temps. of ur exhaust can wont hit high enough temps to expand so u should be good to go....
Old May 29, 2010 | 07:31 PM
KdubyaH's Avatar
June 2011 ROTM
One other thought. I think black heat tape might look cool with the army green paint.....
Old May 29, 2010 | 07:50 PM
__Z__'s Avatar
u mean like black (exhaust) heat wrap?
if u look through all the pages of f4i pics there is a f4i with its mid pipe wrapped in it... it looks a little ruggish but if thats the look ur going for then that could be just the thing if ur gonna go for a clean look ide steer clear
Old May 29, 2010 | 08:30 PM
MEDCOXO's Avatar
I painted the mid pipe with high temp engine paint, then the slip on I used regular paint. I figured that the slip on owuld not get 'that' hot. I used primer, color, then several layers of 'satin clear' as a top coat. I did not want it to be too shiney.
Old May 30, 2010 | 07:39 AM
KdubyaH's Avatar
June 2011 ROTM
How much riding have you done since painting
Old May 31, 2010 | 11:01 PM
MEDCOXO's Avatar
Went out last weekend for a two hour ride in 90 degree heat, and the slip on looks and feels fine. I was worried that it would feel sticky and run, but so far it loks okay. I will be doing more riding this week and will update if anything changes.
Old May 31, 2010 | 11:16 PM
JHouse's Avatar
Mine is painted, but I think it is a fiberglass shell. And I think I might have used "engine block" paint so it would take the heat. It's been a year, and it's still perfect.
Old Jun 1, 2010 | 09:59 PM
axsys's Avatar
check to see if you can find a place to ceramic coat it, possibly called jet coating. its a specific coat for exhausts.
Nick Smith
Jul 31, 2014 03:31 AM
DBEAU
Apr 23, 2010 10:03 AM
OneRedRider
Dec 20, 2007 06:09 AM
