Oil Filter change without removing fairings
Yes its possible and I did it yesterday without using an extender or anything fancy. My oil filter was on too tight by whoever changed it last.
(I used Shell Rotella T6 5W40 and Purolator 14610 oil filter, thanks to everyone on the other oil and oil filter topic here)
I used a Pennzoil Oil Filter Cap Wrench ($4 from Meijer) part #19902 (it has a C written on it) It has a bolt on the end as well as a 3/8 inch square hole in the bolt to use a ratchet wrench.
And a Stanley 85-891 3/8 inch drive Round Head Ratchet ($7 from Meijer) which is a a little less than 8 inches long and will fit inside the fairings.
If you are looking at the filter through the fairings behind the front tire, then you can connect this ratchet to the cap wrench at the 2 o clock position and rotate it to the 4 o clock position which is a good 60 degrees.
