Odometer acting up..
Old 01-04-2011, 09:57 AM
jeffjones's Avatar
Originally Posted by Dragondima
Jeff you seem extremely knowledgeable on the Odometer, you should make a HOW TO:changing the Lights in an Odometer. I'd definitely be interested in seeing one removed from the bike, opened, and then seeing how the LED's sit, how to remove, and add new ones. Interested?
I did a thread when I changed mine.
https://cbrforum.com/forum/f4i-main-forum-11/did-led-gauge-change-117832/
I have a PDF file and word file of the walkthrough but it is to big to attach on here, I tried to copy the word file and put it on here but the pics dont show up.
If you want it, PM me your email and I can send it to you.
Old 01-04-2011, 11:46 AM
mbison83's Avatar
ok so I ended up replacing some of the aftermarket LEDs with the stock ones and now everything works. i will post pics up later.
Old 01-04-2011, 12:12 PM
jeffjones's Avatar
I had 2 bad ones in my batch when I installed them on my bike.
I had ordered a couple of extras just in case they didn't work or I lost them because they are small.
Old 01-05-2011, 04:59 PM
mbison83's Avatar
Here it is.
Old 01-05-2011, 06:26 PM
jeffjones's Avatar
Here it is.
The white looks clean, So did you end up like 3 LED's short?
Old 01-05-2011, 06:50 PM
mbison83's Avatar
Yes, Sir.
Old 01-06-2011, 07:41 AM
Dragondima's Avatar
From where did you order the LED's? I was thinking of just swinging by a sears hardware or something along those lines. Any tips on picking them out?
Old 01-06-2011, 08:50 AM
jeffjones's Avatar
I ordered mine from Digikey.ca/.com and there is also eled.com.
They are about $0.35 each so order so spares because both mbison83 and myself had ones that did not work.
eled.com Part#'s
Blue: EA3528PBC
Red: EA3528SRC
Green: EA3528SGC
Orange: EA3528SEC
Yellow: EA3528SYC
Digi-Key Part#, Manufacturer Part#, Description
475-1007-1-ND, LB T67C-P2R1-35, LED BLUE 465NM CLEAR 2-PLCC SMD
475-1009-1-ND, LV T67C-S2U1-35, LED VERDEGRN 503NM CLR 2PLCC SMD
475-1008-1-ND, LT T67C-S2U1-35, LED TRUE GRN 523NM CLR 2PLCC SMD
475-1004-1-ND, LP T676-L1M2-25, LED PURE GRN 562NM CLR 2PLCC SMD
475-1006-1-ND, LY T676-R1S2-26, LED YELLOW 591NM CLR 2-PLCC SMD
475-1003-1-ND, LO T676-R2S2-24, LED ORANGE 610NM CLR 2-PLCC SMD
475-1002-1-ND, LA T676-R1S2-1, LED AMBER 622NM CLEAR 2-PLCC SMD
475-1005-1-ND, LS T676-Q1R2-1, LED SUP RED 645NM CLR 2-PLCC SMD
475-1010-1-ND, LW T67C-T2U2-3C5D, LED WHITE DIFFUSED 2-PLCC SMD
Old 01-12-2011, 11:16 AM
mbison83's Avatar
eled.com Part#'s
Blue: EA3528PBC
Red: EA3528SRC
Green: EA3528SGC
Orange: EA3528SEC
Yellow: EA3528SYC
Thank you, Jeff.
Old 01-12-2011, 11:35 AM
jp_greenville13's Avatar
Hey Jeff do you know if they have white?
Quick Reply: Odometer acting up..
