Odometer acting up..
Ok. So I've been trying to swap LEDs on the cluster of my bike, and 4 of them do not work. Thats not all, the odometer reads different mileage than before. It jumped from 23k to 28k and some change. How is that possible? Is there a way to correct it? Please help.
Originally Posted by mbison83
(Post 1001444)
When I did it myself I think I had 2 not working because I overheated them when soldering. |
Originally Posted by jeffjones
(Post 1001458)
I would check your resoldering. Maybe you have some solder joints touching on the LCD. For the LED's not working check to make sure they are on the right way, They are polarity sensitive.
When I did it myself I think I had 2 not working because I overheated them when soldering. Also, what is the model number for the LEDs? I'm putting white ones on. |
Digi-Key Part#, Manufacturer Part#, Description
475-1010-1-ND, LW T67C-T2U2-3C5D, LED WHITE DIFFUSED 2-PLCC SMD eled.com part # EA3528RWC-A As for testing them you could put leads from a 12V battery to it and see. |
(Post 1001530)
(Post 1001532)
These dont seem to be the ones I got (yellow in the center). Can I use a 9V battery to test a single LED? If so, which side would be a (+) and which (-)?
I bought a set of white and a set of blue in case I didnt like the blue and no extra shipping cost. Ya you could use a 9V to test it, it would just be dimmer. I believe the marked side is + but if it doesnt work just switch it around. |
(Post 1001537)
I have a set of them in front of me and they are yellow in the middle.
(Post 1001542)
Just used the 9V battery and burned one of them through. There is a burned spot right in the center of it.
I just lold at this thread. Call me if you need help man
Jeff you seem extremely knowledgeable on the Odometer, you should make a HOW TO:changing the Lights in an Odometer. I'd definitely be interested in seeing one removed from the bike, opened, and then seeing how the LED's sit, how to remove, and add new ones. Interested?
