Noob - Changing Gear Shift Lever
Old Sep 18, 2006 | 09:56 PM
ampfp's Avatar
Default Noob - Changing Gear Shift Lever
Hi,
I need to change the gear shift lever (the footrest of which snapped off recently) on my '02 F4i. I'm a sportbike noob equipped with a little mechanical intuition from past projects. Should I try to replace this myself or would it be better done at a shop (probly for $80!) ??
V
Old Sep 18, 2006 | 10:24 PM
gixxereater's Avatar
Default RE: Noob - Changing Gear Shift Lever
DO IT. All you need is probably a 10-12mm wrench. Loosen the bolt that holds the lever onto the output shaft of the tranny. (Not really the output shaft but you know what i mean) Slide it off the splines. That'll get your linkage off, now just unbolt the rearset and be done.
Old Sep 18, 2006 | 10:28 PM
Blackdog F4i's Avatar
That is a REALLY simple fix. If you are able to program your VCR this will be a snap.
Old Sep 20, 2006 | 08:29 AM
JaSoN's Avatar
some of those VCR's are a bit tricky...
Old Sep 20, 2006 | 12:50 PM
JVracer04's Avatar
ORIGINAL: Blackdog F4i
whats a VCR?
Old Sep 20, 2006 | 01:21 PM
Oh, I mean Tivo or DVR. I must be dating myself by mentioning those funny "tape" things.
Old Sep 20, 2006 | 04:15 PM
Advert25's Avatar
yup its like wrenching on the ol' beta or 8 track right?
Old Sep 20, 2006 | 06:29 PM
ampfp's Avatar
Thanks!
Trent Dog
Jul 9, 2012 06:32 PM
Klink
May 24, 2009 09:41 PM
gatorguy
Apr 26, 2009 08:29 PM
gatorguy
Apr 24, 2009 04:11 PM
