noisy clutch bearing and sticking gears
Old Nov 25, 2007 | 02:13 PM
kennethr's Avatar
Default noisy clutch bearing and sticking gears
Apologies if I have broken any rules , but I am a new member and I also added this post to the new memebers site , apologieds for the duplication but I wanted to inform as many people as possible because this seems a common problem[/align][/align]As a relatively new memeber and a returning to bikes at over 40 memberI did a recent search for clutch problems on my brand new cbr 600f ( 2006 model purchasedin Aug 2007)and found that many members had similar faults, noisy clutch release bearing and diiificulty getting down the gears ifI did a stop without fully going down the gear box.[/align][/align]Well ,I just put my bike in for its first 1000 k service , I told the mechanic all my problems ( 8 rides 6 stuck gears, unable to get back to first after stopping in a higher gearand a noisy clutch release bearing)[/align][/align]I picked up the bike 3 days later and what a difference, the clutch is a smooth as silk and feels oh so sweet, the bearing noise is still apparent but he assures me that is normal, he told me the shifting down problem was from sticking clutch plates which were roughed up and all he did was polish them up with some emery paper and a light file[/align][/align]if you are having same problems (as many of you reported on my search) then get your mechanic to have a good look, maybe they are swinging you a line , if i get any more problems I will keep you informed[/align][/align]ride the life out of it, who knows what is coming[/align]
Old Nov 26, 2007 | 05:18 AM
chedaf4i's Avatar
Default RE: noisy clutch bearing and sticking gears
good info... i have similar problems
Old Dec 13, 2007 | 07:37 PM
webb10008's Avatar
the noise is when shifting down to 1st gear.. same problem with my 06f4i? how much will it cost me to have it fixed..
thanks and safe riding
Old Dec 13, 2007 | 07:48 PM
thirdgenlxi's Avatar
Ironmang
You do know that it's [usually] not supposed to go into 1st from a higher gear while you're completely stopped, right? It's a constant mesh transmission, if you don't put it in N and let the clutch out first, just going from 2nd to 1st in one sweep while stopped it won't go. You gotta roll it a little bit and it'll go right in
The clutch basket making noise is normal on alot of bikes (if it's the one that goes away when you pull the clutch in).
Glad to hear it worked out for ya though... whatever was going on with it
cbreric
Aug 17, 2018 08:14 AM
fthree
Jun 1, 2010 10:14 AM
gregtutch
Aug 20, 2008 12:56 PM
kennethr
Dec 4, 2007 04:42 PM
crpry
Sep 18, 2007 07:10 PM
