No headlights, horn, brake light etc.
Hey guys,
So I'm gonna work on my F4i tomorrow, and here's the issue.
My headlight doesn't work. It's plugged in, and the bike starts and runs/rides.
Also, the horn doesn't work either.
I can't test the turn signals since they have yet to be installed. (Flushmount both front and rear)
The rear running light (on the tail light) turns on, but the brake light doesn't turn on when you pull the brake lever.
Any help is appreciated!
First check all the fuses and connections, specifically the main headlight harness. Proly should replace ALL the bulbs. And check the adjustment on the brake lever sensors. I adjusted mine to turn on the light just before the pads grab. If you got the signals used, get a multi meter and double check which wire is hot and which is ground, some aftermarkets' use a green wire for the hot, and on the bike green is ground. If they're new, follow the directions.
Definitely the fuses... it happens some times.
Is any of the wiring questionable? If the contacts of the indicator wires touched then you have found the cause - insulate them or wire them up to the new indicators before continuing.
Then? Just replace the fuse... they are cheap.
Fuses... If you have any wiring mods you should double check the connections whether they are connected to the proper wires and if they have quality connections (shouldn't be connected with wire nuts or twisted together and taped). If the fuses are blown, there is a reason...
Hayden06F4i
Jun 17, 2008 09:50 AM
mkhaynesaz
Jul 13, 2006 04:36 PM
