No Head Lights
Old May 2, 2013 | 12:29 PM
phiz36's Avatar
New Member
Default No Head Lights
Hey.
This is my first post. I'm new to everything here. New to riding and maintenance. So please forgive any rules that I'm breaking.
I tried searching but...you know.
My lights aren't working. 2005 CBR600 F4i. has about 15,000. I had my chain and sprockets replaced and wheI got it out of the shop the lights weren't working. I didn't notice till the cop told me. It was dusk. FML.
My Low beam is usually on automatically. And when I turn on the High beams the nice little blue indicator turns on. None of these things are happening. No head lights at all and when I hit the High Beam switch the indicator light doesn't turn on.
I've tried to check the exposed connections. Everything SEEMS in order.
I'm taking it back to the shop today but they aren't going to admit any fault.
I've heard that this is common?
Old May 2, 2013 | 01:05 PM
kevin...who?'s Avatar
Check your fuse box under your seat. Could be a blown fuse. 10A. This is the easiest and quickest troubleshoot so start there.
Old May 2, 2013 | 01:55 PM
phiz36's Avatar
New Member
Is it easy to tell if a fuse is out?
Old May 2, 2013 | 02:52 PM
chambers's Avatar
You have to pull the fuse out to see if it's blown. Google blown fuse vs. good fuse and you'll see a picture of each. Check any fuses that have to do with your lighting, there is usually a diagram on the fuse box lid that indicates which fuses do what and which are spares. Are the signals and brake lights working?
Old May 2, 2013 | 03:00 PM
CorruptFile's Avatar
June 2013 ROTM
I've heard of fuses looking fine but be blown. Best way to check us with a multimeter. That being said, if your fuses are fine, isn't the f4i headlight driven by a relay? Could be bad...
Old May 2, 2013 | 03:49 PM
phiz36's Avatar
New Member
The taillights turn signals, and break lights all work fine. It is only the headlights that aren't.
Old May 3, 2013 | 02:10 AM
rd91si's Avatar
Check the starter switch it sticks sometimes, when you push it the lights shut off.
Just give it a tug to make sure it came back all the way.
Old May 3, 2013 | 09:01 AM
Incompatible's Avatar
Common problem, the switch gets sticky over time and eventually doesn't make electrical contact when released. Had this problem about a year ago and used a spray dry lube on the switch. Worked fine and have not had a problem since.
Old May 3, 2013 | 11:01 AM
Yin-Yang's Avatar
I had this problem as well during my rebuild. I found that I had snapped wires on the switch side. Maybe could be the same for you.
horse_power777
Mar 22, 2011 09:03 AM
Jeff0044
Dec 14, 2010 02:31 AM
ny00jp
Dec 27, 2008 11:39 PM
radical rich
Sep 19, 2007 02:45 PM
CBR Blue
Sep 14, 2006 05:12 PM
