no fire on plugs
Old Jan 16, 2013 | 06:40 PM
keveka2's Avatar
Default no fire on plugs
ok i bought a 2005 honda cbr f4i off a guy for a grand it was pretty bad but had all the parts the wiring harness had been hacked... all farings off anyways i cant get the coils to get the pulse for them to fire.. it has 12v to them.... heres whats been done i replaced the cdi/ecu also checked all sensors replaces the cam sensor the bank,pulse generator ... i replaced the whole wiring harness ive took it to the local shop they cant find anything wrong... we have even got a cdi off a running bike.... any suggestions would be great.....
Old Jan 16, 2013 | 06:44 PM
74demon's Avatar
Headlight plugged in?
There also may be a diode on the bottom of the ignition switch the sends 9.3v signal to the ecu. (Not sure if your model has it or not)
Old Jan 16, 2013 | 06:48 PM
keveka2's Avatar
well everything is plugged in and there is power ad signal going into the ecu just nothing coming out
everything is plugged in and theres power to the ecu as well as signal its just not going to the cdi half and the switch works properly
ive checked all that and it all good thats what i dont understand everything works as it should and has good #s... the ecu gets signal and doesnt translate it to the cdi half but the ecu/cdi works fine on other bikes.. it also wont let me pull up the diagnostic lights..
Old Jan 16, 2013 | 07:43 PM
stlcbr600f4_newb's Avatar
i would check your kickstand switch....is it turning over???? if it won't start or turn over that may do it... or bank angle sensor...
but those are only if it is not attempting to start at all... check fuses??? stupid question but some times the simple things get over looked...
let me know what you come up with i am curious
Old Jan 16, 2013 | 07:50 PM
keveka2's Avatar
all checked and bypassed it turns over fine just no 12 v pulse to the coils
Old Mar 1, 2013 | 06:11 PM
keveka2's Avatar
it ended up being a resistor in the ignition switch which was reading 12v when it needed to read 5v replaced the switch and good to go thanks for all the help
Old Mar 1, 2013 | 07:18 PM
Taw1985's Avatar
The pink wire should read 9 Volts to the ECU...if it is not then the Diode in the ignition is dead.
I just went through this last week.....After a week of tearing the bike all the way down to the frame and back I finally figured it out, Thanks to the CBR members here!
Old Mar 8, 2013 | 10:51 PM
lawdog850's Avatar
Can you explain what wire you are talking about? The pink wire on the bottom of the ignition? I'm having the same problem. Everything seems to be working. All sensors check out but no spark.
Old Mar 8, 2013 | 11:26 PM
74demon's Avatar
Yes, the pink wire coming out of the ignition. If you look at the bottom of the switch, you will see a little diode. Check the voltage at the pink wire, it should read 9v or so. Its a security feature to prevent the ignition from being bypassed.
sj66
Aug 12, 2012 06:43 PM
nabobblaster
Sep 12, 2008 06:29 PM
bond67
Jul 2, 2008 10:37 PM
one_sick_stang
Oct 2, 2007 12:17 PM
sudz
Sep 3, 2006 09:06 PM
