Newbie sprocket question
RE: Newbie sprocket question
The front sprocket is easy to get to, Just undo the little plastic cover over it, secured by 2 8mm bolts. Also there is a metal shim behind the plastic that comes off with everything. Once it is off, all that stands in your way of having a liberated sprocket is a single bolt I think it is a 14mm. That is all there is to it.
