-1/+2 sprocket kit...question
Old Apr 16, 2013 | 11:08 AM
wisco's Avatar
Default -1/+2 sprocket kit...question
How much of a difference will I see if I get one smaller on the front and two more on the rear? Ive never rode a bike with an after market sprocket kit so I have nooo idea what it would do. I know its basically like a lightweight flywheel but what are the positives/negatives with it? Would you suggest getting one? Thanks
Old Apr 16, 2013 | 11:12 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Go to the Gearing Commander website, load your bike's data from the drop-down menu and experiment with different gearing to see how it affects speed and rpm.
Old Apr 16, 2013 | 02:20 PM
wisco's Avatar
Thanks jeff.
Old Apr 17, 2013 | 06:23 AM
mark966's Avatar
One down two up is a good combo for a 600 road bike - I've done exactly that on a cbr 600rr. You'll definately be able to feel the difference when accelerating. You should also be able to change the sprockets out without worrying about having tho get a longer or shorter chain. I use one down three up on my track bike
Old Apr 17, 2013 | 08:10 AM
Conrice's Avatar
i've done it on a 954 and an f3.
the only real negatives i can think of would be a)your speedo is going to read a little faster than you're actually going b) the motor will spin faster when highway cruising.
Old Apr 17, 2013 | 12:51 PM
wisco's Avatar
I ended up getting a gold chain and -1 on the front and stock sizing on the back. They had a kit that was only $190 so I just got that. A lot cheaper than piecing together parts. Not sure how much a difference -1/+0 is going to be but I needed new sprockets and a new chain so we'll see how it rides.
Old Apr 17, 2013 | 12:55 PM
Conrice's Avatar
it won't be much, but that combined with a 520 chain should be a little noticeable
Old Apr 17, 2013 | 10:25 PM
Scott91370's Avatar
You'll be able to tell the difference at low speed hard acceleration but at higher speed not so much. I did that then switched from stock to -1,0 then -1,+2 and that was a nice improvement. Your rpm at any given speed in 6th gear will be about 600 higher than oem but its not too bad.
06 Tribal 600rr
Feb 7, 2013 08:33 PM
irocthestreet
Jul 9, 2009 03:01 PM
Kelo718
Apr 4, 2009 03:19 PM
tillersluck1117
Mar 19, 2007 11:18 AM
mflave007
Nov 7, 2006 04:10 AM
