Lights for F4i
Old Mar 7, 2006 | 09:25 PM
wordizbon's Avatar
Default Lights for F4i
I need to buy some turn signals for the front of my F4i. I don't want the factory ones since they seem to break off easy when you go down. Any suggestions on where I can purchase some lights that wont break easy?
I also want to be able to keep both headlights on without having highbeam on. Any suggestions on customizing the headlights. I don't know why they made it like that. Look stupid with half a headlight on.
Old Mar 7, 2006 | 09:39 PM
Turnin20s's Avatar
Default RE: Lights for F4i
As far as the signals, get a flush mount such as Hotbodies or Greggs flushmounts. And the headlights you may run into some issues, such as the 2 reflectors are different so the light won't shine in the right spot and you will have to rewire the headlights since the stock bulbs are a single filment. And by doing this and have 2 beams on at once you will be putting a bigger load on your electrical system and may drain your battery when your sitting at idle in traffic. If you have any experience with wiring it shouldn't be too hard to pull off, but take your time and do it right. I know alot of kawasaki guys are doing it with the lights and I'll see if I can find it and redo it so I don't have to link you over.
-Jesse-
Old Mar 12, 2006 | 06:07 AM
DThompson's Avatar
www.DennisKirk.com
Old Mar 15, 2006 | 06:53 PM
SpeedDemon12's Avatar
heres a great writeup on doing dual headlights..the h4 bulbs they use are dual filament so they have high and low beams...with this setup you level out the high beam you have now so they are both low beams then when you turn on the high beams both low beams filiments go out and the high beam filiments light up... he has a switch set up so only the original single low beam can be turned on incase it starts to drain his battery but it doesnt seem to be much of an issue
http://cbrworld.net/forums/thread/42405.aspx
xankriz
Apr 2, 2012 03:02 PM
fordfenatic09
May 17, 2011 10:40 AM
deerslider
Aug 24, 2009 08:23 PM
Ocelaris
Dec 7, 2006 02:14 PM
Moe Blike
Sep 12, 2006 12:40 PM
