newbie please help 2001 f4i throttle problem
Old Jul 7, 2009 | 12:59 AM
Koen's Avatar
Default newbie please help 2001 f4i throttle problem
when I wanna rip on the throttle sometimes the power will cut off and then come back, like its choking or something, and on long rides when remain on a certain speed it will do the same constantly power cutting off and then coming back, could it be some electrical problem? And oh yeah the bike is stock except I bought it with no muffler so i am running a straight pipe right now.
Old Jul 7, 2009 | 10:24 AM
bakesf4i's Avatar
get rid of the straight pipe and see if that makes a difference, also are you lugging the bike around in low rpms?
Old Jul 7, 2009 | 04:58 PM
Koen's Avatar
I'm not lugging at low rpms but I will get a muffler on it and see what happens. Thanks
Old Jul 7, 2009 | 06:23 PM
mike and ikes's Avatar
I agree, get a good muffler on it. Straight pipes are nice and loud but the engine needs to be tuned for it.
Also, check your battery and charging system. A poorly charging battery can play all sorts of hell.
Old Jul 7, 2009 | 09:21 PM
drunkinmist's Avatar
Sprocket Hauler and Savior
Agreed if the bike was not set up and tuned for straight pipes which most aren't then you are losing back pressure which will make your bike cut out.
Old Jul 7, 2009 | 11:42 PM
Koen's Avatar
thanks for the tip I will work on it this weekend and see how everything goes. thanks alot everyone
Old Jul 8, 2009 | 07:04 AM
orags's Avatar
Check your battery terminals first. Its the zero-cost thing to do.
Old Jul 8, 2009 | 10:44 PM
j4eric's Avatar
- battery terminal/loose ground connection
- bad/contaminated fuel (use stabil, marine grade if you have it)....poor quality fuel
- crimped hose/line beneath the fuel tank
Nick68
Feb 7, 2010 03:49 PM
bsims13
Mar 30, 2009 07:58 PM
PhantomInABox
Aug 29, 2008 09:12 AM
toaliosis
Jul 3, 2008 11:50 PM
usanavyguy
Apr 3, 2008 08:21 PM
