need some help with a quick question
Old Aug 1, 2010 | 04:31 PM
StEv3nS's Avatar
Default need some help with a quick question
I have a '02 f4i and I need to put on a new right crankcase cover as i cracked it pulling a wheelie too far back. the question is, do i need a gasket and/or sealent when i do so, cause on the partlist i was looking at there's no gasket, and the shop i go to said no based on the same evidence. and is there anything else i should know about doing it cause i'm assuming its just gonna be pull the old cover off and put the new one on i hope. Any advice is appreciated, thanks in advace
Old Aug 1, 2010 | 09:00 PM
115Degrees's Avatar
Don't do wheelies.
Old Aug 2, 2010 | 01:03 PM
StEv3nS's Avatar
glad people are so clever on forums...i do them in safe places only as recreation, just becuase its scary for you, doesn't mean everyone can't do them. im not complaining about my bike breaking because i did a wheelie, i knew it was inevitable and it happens, just asking for a quick tip so i can fix it asap. not a smart *** remark from an immature child.
Old Aug 2, 2010 | 01:06 PM
__Z__'s Avatar
April 2011 Ride of the Month
use blue rvt (aka gasket sealant) and call it a day (there is no gasket for that cover)..... btw the "glad people are so clever on forums" isnt going to get you very far on this forum
Old Aug 2, 2010 | 01:14 PM
StEv3nS's Avatar
thanks. didnt think there was a gasket, but i know there is on the older ones so i wanted to make sure.
Old Aug 2, 2010 | 01:46 PM
115Degrees's Avatar
Good comeback, I certainly learned my lesson. I'll be more careful next time so I don't offend the more sensitive among us.
Old Aug 3, 2010 | 01:51 AM
joelacer's Avatar
If you're so set on doing wheelies, you might want to look into buying a cage or race rails. You can find used ones pretty frequently on stuntlife.com.
Old Aug 3, 2010 | 07:15 PM
vangill's Avatar
July 2010 ROTM
holy crap, if your gonna be like that how hard is it for you to just use some rtv or silicone on it to make a gasket, the same stuff you'd use on any other surface of a motor to seal for oil-the gray kind, yes you can use others and it will work fine too, or you can use the kind that honda makes, or you might not even run one if you dont want. its really not that hard.
just put a good bead around the egde before you bolt it up and let it sit over night and then ride it like normal
Old Aug 3, 2010 | 08:28 PM
xjoewhitex's Avatar
3 posts, and you've already lost respect on this forum. Well done, glad to see ya. xD
And thats not being clever, thats being straight up.
TattooguyF4i
Mar 31, 2010 12:39 PM
CBR_GreenMonster
Aug 13, 2009 08:00 AM
viva_brasil
Jun 9, 2008 04:38 AM
rke2121
Feb 6, 2008 05:45 PM
bboi
Jul 9, 2007 10:08 PM
