Need help, not starting
Old Feb 4, 2012 | 08:29 PM
omg209's Avatar
nice to meet you, well if you have already did that you can always check the fuses under the seat. if there is no problem there turn your key to on and see if you have FI light showing, that might be a problem but i am a noob myself.
Old Feb 4, 2012 | 08:30 PM
omg209's Avatar
ah, could be something with headlights, if they are not connected i hear the bike will not start..
Old Feb 4, 2012 | 09:18 PM
nickp123's Avatar
^the pump wont even prime if theyre not connected so thats not the problem. Pull one of the plugs, ground it out and start it and see if youve got spark. If you do then you can eliminate that. Any other info on when/how/why this started happening? was the bike running one day then all of a sudden it wouldnt start? Did something happen, were you working or changing anything on the bike?
Old Feb 4, 2012 | 11:25 PM
Sprock's Avatar
try flipping it down to reserve
Old Feb 5, 2012 | 03:16 AM
nickp123's Avatar
welll if youve got spark and youre getting air that only leaves fuel since you havent messed with the timing or engine or anything. A little extra fuel stabilizer wont mess anything up, itd have to be a significant amount and itd be more likely detonate your motor than just cause it to not start though.
BlackDogIron
Sep 14, 2017 05:47 PM
Nevets
Nov 8, 2010 04:45 PM
BrokeCollarBone
Nov 24, 2009 01:24 PM
bh1
Dec 7, 2007 02:36 PM
steeper
Jun 23, 2006 02:49 PM
