Need Help with my clutch handle
Old May 2, 2009 | 05:48 PM
eljrc16's Avatar
Default Need Help with my clutch handle
My F4i clutch handle seems to get stuck when you pull it in I dont know if it's the screw holding it. because I barely changed the clutch cable its brand new. How hard of a fix is this?
Old May 2, 2009 | 11:31 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
The clutch cable mechanism is pretty basic. Your clutch lever is merely held on by the chromed flat-head screw on top, which serves as a pivot. Loosen it & see if that doesn't fix the binding. Wouldn't be a bad idea to lube the lever while your at it.
If that's not it, then you might have a kink in the line, or perhaps it's pinched somewhere. Did you lube the cable prior to installation?
Old May 2, 2009 | 11:43 PM
eljrc16's Avatar
what should I lube it with W-40 or with chain lube some guy put the bale on for me dont know if he lube it once he installed it.
Thanks
Old May 3, 2009 | 02:28 AM
Incognito's Avatar
With the lever itself, you can just use grease (lithium). If it's a brand new clutch cable, it shouldn't be binding, even without lube. Check to see that the cable runs from the lever, to the right side of the engine freely, above the clutch cover.
Ideally, you want to use a cable lube, but you'll need a special tool to do that. I've even heard of guys lubing their cables with automatic transmission fluid. But again, to do that, you'll need to remove the cable from the lever. My guess is that the lever is on too tight. Loosen the screw and see if that doesn't aliviate the tightness.
CrashTECH
Nov 18, 2009 08:19 AM
DRLOWZ
Nov 25, 2008 03:00 PM
cbr6oo
Oct 25, 2007 05:25 PM
gregp
Apr 14, 2007 04:55 AM
