Is it my linkage or my tranny?
Old Jun 7, 2010 | 12:47 PM
killmime1234's Avatar
Default Is it my linkage or my tranny?
This morning I tried to take off with my brake lock still attached.
When I fell over on my left, I did SOMETHING to either my shifter or my tranny. Now when I ride my shifter violently rattles when I'm moving.
It keeps rattling even if I try and damper it with my foot, and it feels like the source is coming from the tranny.
It's very hard to diagnose exactly what's wrong with it because it only rattles like that when the bike is in motion. I tried putting the bike in N and revving the engine up to see if RPM had anything to do with it, and apparently it did not. No amount of revving caused the "vibrations" i feel when actually riding.
Has this happened to anyone else? Does anyone have a fix? Do I just need to take the bike in to a shop (I'm broke so this is hopefully not the case)?
Thanks for any help!
Old Jun 7, 2010 | 12:53 PM
Junior2552's Avatar
sound like the shifter linkage. tranny's don't tend to just go bad after getting dropped. make sure the shifter linkage is tight, and fastened down correctly, and make sure it's not bent.
Old Jun 7, 2010 | 01:00 PM
That's what I would hope, but do you think that's the case since it's such a strong vibration? I mean even putting my foot on it, intentionally trying to suppress it doesn't seem to help.
I'm kinda new to bikes though, so I'm not sure what exactly can be tightened on the linkage. So far I can only find two bolts and they seem to be tight.
Old Jun 7, 2010 | 03:03 PM
So, I figured it out. It turns out I bent the mounting bracket that holds the peg and shifter and that was causing the linkage to rub against the chain which is what caused the vibration I was feeling. I crowbarred it back so that it was straight.
Seems fixed, although one thing I have noticed is some harder shifting from neutral into 1st or neutral into second. I'll mess with that later though.
Dilandau00
Nov 14, 2014 04:53 PM
5p00f3r
F2 Tech
Feb 1, 2012 05:55 PM
jdsjunkyard
Dec 11, 2010 05:30 AM
jkarner
Nov 29, 2008 10:07 AM
Foght
Jan 11, 2008 04:52 PM
