Is my battery going bad? Dimming lights...
Old 01-05-2009, 07:27 AM
JeremyGSU's Avatar
Default Is my battery going bad? Dimming lights...
Hey guys, lately I've noticed when I'm sitting a light with my turn signals on and my brights on that my headlights dim as my turn signal flashes and then in between flashes my headlights get bright again. So it's appears that my turn signal and my headlights/taillights are flashing together. lol
Would a battery cause this? The bike starts up fine. Any other ideas if it's not the battery?
Thanks.
Old 01-05-2009, 07:56 AM
Default RE: Is my battery going bad? Dimming lights...
I would say it could be the battery. Check your connections around the battery and maybe look at your fuses as well. If nothing is wrong, then replace the battery. They are fairly cheap. Less than 50.
Old 01-05-2009, 08:21 AM
redzintimidator's Avatar
both my bikes so far have done this. When you rev it the headlights should get brighter as well...I believe all this is normal
Old 01-05-2009, 10:07 AM
StrikeAnywhere's Avatar
You probably have one of the F4i models equipped with mood lighting.
Not a big deal. Your bike is running of power from the stator when the engine is running. Its turning slowly and not developing as much power just like the alternator on a car. Only thing you need to worry about with your battery is if it quickly starts your bike when you crank it up.
Old 01-05-2009, 10:49 AM
Stephens's Avatar
" Here's your problem Marty, this things made in Japan"
Old 01-05-2009, 11:32 AM
ampfp's Avatar
If you have the usual (filament) turn signals, it's possible that a bad battery could cause a momentary dimming of the headlight each time the turn signal starts to flash... if you have LED turn signals, they shouldn't dim the lights... check the wiring to make sure there's no minor short causing a large current draw everytime the signal flashes.
Do you have starting problems?
now your battery could lose charge if you only do short rides. It takes up to half hour to charge the battery if it's been sitting for a few days. Even for a good battery.
If you decide your battery is bad, I got a gel battery off ebay for 40 shipped or something and its worked great for a year even in cold and dropping the bike etc.
Old 01-05-2009, 03:23 PM
orags's Avatar
With the engine at idle, the lightspulse very slightly with the turn signals on. A slight rev up to about 2000rpm will reduce the those signs.
Normal operations, nothing to worry about as long as your engine fires up once you try to start it.
Old 01-06-2009, 08:27 AM
JeremyGSU's Avatar
ORIGINAL: Stephens
Haha. "Doc, all the best stuff is made in Japan".
"Unbelievable".
Thanks for the replies guys.
Old 01-06-2009, 08:58 AM
fishfryer527's Avatar
get it load tested. A new battery is about 270cca. It is the only way to tell.
SpeedFreak*859
12-07-2012 02:48 AM
Greg Hewitt
05-15-2011 01:56 AM
scooterc14
02-08-2011 08:32 AM
cbrjoker
10-07-2010 10:41 PM
AmericaFcukYeah
05-27-2008 01:29 PM
Quick Reply: Is my battery going bad? Dimming lights...
