MOTOR OIL TYPES
RE: MOTOR OIL TYPES
You shouldn't use any synthetic oil that has moly.. which is 90% of all synthetics... you can buy a special synthetic from Honda specifically without moly. The reason for this is the clutch. Some kind of slippage issue. You would be fine with conventional motor oil and you should use it to break in your bike... but once you switch you should not switch back.
