missing, running like crap
Old May 20, 2006 | 10:26 PM
01600F4i's Avatar
Default missing, running like crap
Bike was running perfect the other day, not missing a beat, put it in the garage, shut it down. This was thursday. Now it's saturday, I go outside, and start it up, something isn't totally right. I figure the bike is just cold, maybe it needs to run out a little gas. Bike is now warm, and I take off and it has a missing sound. I thought maybe it was bad gas, and the tank was low, my reserve was on. So I went and filled it up with premium. No difference, ran that tank completely out throughout the day, and it's still doing it.
Pulled the tank, pulled the spark plugs, etc... Plugs were a bit fouled, gap wasn't perfect, electrodes were worn. Bike has 15,500 miles, stock plugs. Cleaned them up, wire wheeled the carbon off. Put it back together, still the same thing. I'm confused. I am hoping that new plugs is all I need, but if not, what else should I look into?
I just find it weird that it ran perfect when I parked it, and now it's a night and day difference, total loss of power. Feels like it's running off 3 cylinders.
Old May 21, 2006 | 04:19 AM
Air4Andy's Avatar
Default RE: missing, running like crap
Well, start to diagnose the problem yourself.
-1st remove your plastic (if you haven't already) so you have access to all your plugs and wires.
-With the bike running and warm at a constant idle, take a pair of insulated pliers, and if you would like wear a pair of insulated gloves (a plug wire tool works best, just don't grab the wire with bare metal tools and wet hands... but even if you get a zap, it won't kill ya, just scare ya) pull of one of the plug wires. You should hear a noticable change in engine rpm and it will run even more poorly. Put that wire back on then. When you get to a cyl where you pull the wire and you hear no noticable change in the engine, that is the cyl giving you your problems. Now focus on the plug, wire, wire insulation, connectors, ignition for that cyl. If all seems well with the spark, check for fuel problem or worse a compression problem. Chances are spark is you man. I'd change the plugs, wires anyway.
Old May 21, 2006 | 04:14 PM
chaos321's Avatar
You can also "quickly" touch the head pipes to see which one is running cool. It's a little faster(and more painful) than taking your tank off first, but you will probably need to get under there anyway.
Old May 22, 2006 | 05:19 PM
01600F4i's Avatar
well, got it running beautifully again. Amazing how plugs can just go bad so quick. The stock NGK's that honda recommends were 25/piece! So I picked up the Cr9ehix plugs for like 13/piece. I found them at sparkplugs.com for $7 but I couldn't wait a week. We've had rain here in michigan for about 2 weeks straight (literally). Extra 20 bucks to be up and running today. Did an oil change while I was in there. Washed her too. Today was a good day
Love it.
Old May 22, 2006 | 05:30 PM
Jaybird180's Avatar
What brand plug is that?
Doesn't the stock ECU store maintenance codes?
Old May 22, 2006 | 10:47 PM
01600F4i's Avatar
It's an NGK. http://www.sparkplugs.com/results_cr...CrossWarning=1
check out that link. It shows which plugs will work for the bike. I got the very first one, only I paid almost twice as much per plug.
Old May 23, 2006 | 01:23 PM
Jaybird180's Avatar
YOu should post that info in the maintenance section.
toleya12
Mar 8, 2014 05:13 PM
BannWorthRulz
Mar 13, 2012 05:19 PM
cyclonepoker
Feb 20, 2012 11:49 PM
quadracer18
Jun 1, 2010 10:19 PM
flavadavecbr
Dec 14, 2005 02:31 PM
