MAP Sensor Code and Idle Issues
Old Apr 27, 2012 | 05:20 PM
cbrryno's Avatar
Unhappy MAP Sensor Code and Idle Issues
Hey guys,
Every once in a while my bike with throw an FI code at me. 2 blinks. Which means "Bad MAP Sensor". I replaced the MAP sensor and the issue didn't go away. When this happens, the bike runs EXTREMELY low on idle almost to the point of dying. About 10 seconds later it will MAP itself out flashing the code. At this time it idles fine. Once the bike is at full operating temperature I can shut it off and restart it without the any problems and the MAP code is no longer there. Any ideas on this?
Also,
I live at about 4000-5000 feet elevation. Up here it seems like the bike is SLUGGISH. Almost like a carbed bike jetted for sea level. Very rich feel, sound, and smell to it. Since I already replaced the MAP sensor... What else should I be looking for?
Any help would be much appreciated. Thanks!
Old Apr 27, 2012 | 05:29 PM
74demon's Avatar
check for vacuum leaks and test the source vacuum at the line. other than that, test your voltages at the ecm.
Old Apr 27, 2012 | 05:45 PM
cbrryno's Avatar
Are implying to whip out the can of carb cleaner and go to town on the vacuum lines while at idle? What's the best way to check these lines?
Old Apr 27, 2012 | 05:47 PM
cbrryno's Avatar
Also, I still have the O2 sensor in the exhaust. I'm thinking to just bypass the O2 sensor since I'll be putting on an aftermarket pipe anyway. Doing so will eliminate that from reading wrong...
Old Apr 27, 2012 | 05:49 PM
74demon's Avatar
the best way is smoke if you have a smoke machine, but carb cleaner works too if you dont. hook a vacuum guage to the hose to make certain its within spec.
Old Apr 27, 2012 | 10:52 PM
cbrryno's Avatar
So, take it in to the shop.....check. Hahaha.
Old Apr 28, 2012 | 05:57 PM
cbrryno's Avatar
Got it fixed.... You were right bro. It was vacuum. Actually.... the hose to the MAP sensor was completely clogged.
Old Jan 21, 2013 | 02:48 AM
Kopi Ko's Avatar
I had same issue, turn out that he MAP vacuum hose was blocked.
Thanks cbrryno, you just save me a lot from buying a new MAP sensor
cbrryno
Sep 9, 2011 07:44 PM
k2comer
Feb 7, 2008 03:46 PM
redlink15
Jun 13, 2007 12:05 PM
The Twisted Grip
Sep 15, 2006 06:41 PM
The Twisted Grip
Jul 10, 2006 01:49 PM
