Map sensor
Hey guys/ladies. I believe i have a map sensor that went out, fi light blinks twice. When looking for the part i can only find ebay parts, used. Question is, are those reliable and when i enter the part number, it says fits honda or acura car. Im very new to this so any advice would help. Thanks in advance.
Here is the Honda part number and it's a very common sensor. 37830-MCF-003
It's used on the following motorcycles.
ASSEMBLIES WHERE 37830-MCF-003 IS USED
2000 CBR900RR A - WIRE HARNESS (1)
2000 CBR900RR AC - WIRE HARNESS (1)
2000 RVT1000R A - THROTTLE BODY (ASSY.) ('00-'01)
2000 RVT1000R A - UPPER COWL
2000 RVT1000R AC - THROTTLE BODY (ASSY.) ('00-'01)
2000 RVT1000R AC - UPPER COWL
2001 CBR600F4 A - AIR CLEANER ('01-'06)
2001 CBR600F4 AC - AIR CLEANER ('01-'06)
2001 CBR900RE A - WIRE HARNESS (1)
2001 CBR900RE AC - WIRE HARNESS (1)
2001 CBR900RR A - WIRE HARNESS (1)
2001 CBR900RR AC - WIRE HARNESS (1)
2001 RVT1000R A - THROTTLE BODY (ASSY.) ('00-'01)
2001 RVT1000R A - UPPER COWL
2001 RVT1000R AC - THROTTLE BODY (ASSY.) ('00-'01)
2001 RVT1000R AC - UPPER COWL
2002 ARX1200N3 A - CYLINDER HEAD COVER
2002 CB900F A - AIR CLEANER
2002 CB900F AC - AIR CLEANER
2002 CBR600F4 A - AIR CLEANER ('01-'06)
2002 CBR600F4 AC - AIR CLEANER ('01-'06)
2002 CBR900RR A - WIRE HARNESS (2)
2002 CBR900RR AC - WIRE HARNESS (2)
2002 FSC600 AC - THROTTLE BODY
2002 RVT1000R A - THROTTLE BODY (ASSY.) ('02-'05)
2002 RVT1000R A - UPPER COWL
2002 RVT1000R AC - THROTTLE BODY (ASSY.) ('02-'05)
2002 RVT1000R AC - UPPER COWL
2002 VFR800 AC - AIR CLEANER
2002 VFR800A AC - AIR CLEANER
2002 VTX1800C A - WIRE HARNESS
2002 VTX1800C AC - WIRE HARNESS
2002 VTX1800R A - WIRE HARNESS
2002 VTX1800R AC - WIRE HARNESS
2002 VTX1800S A - WIRE HARNESS
2002 VTX1800S AC - WIRE HARNESS
2003 ARX1200N3 A - CYLINDER HEAD COVER
2003 CB900F A - AIR CLEANER
2003 CB900F AC - AIR CLEANER
2003 CBR600F4 A - AIR CLEANER ('01-'06)
2003 CBR600F4 AC - AIR CLEANER ('01-'06)
2003 CBR600RR A - AIR CLEANER
2003 CBR600RR AC - AIR CLEANER
2003 CBR900RR A - WIRE HARNESS (2)
2003 CBR900RR AC - WIRE HARNESS (2)
2003 FSC600A AC - THROTTLE BODY
2003 FSC600D AC - THROTTLE BODY
2003 RVT1000R A - THROTTLE BODY (ASSY.) ('02-'05)
2003 RVT1000R A - UPPER COWL
2003 RVT1000R AC - THROTTLE BODY (ASSY.) ('02-'05)
2003 RVT1000R AC - UPPER COWL
2003 ST1300 AC - THROTTLE BODY (ASSY.)
2003 ST1300A AC - THROTTLE BODY (ASSY.)
2003 VFR800 AC - AIR CLEANER
2003 VFR800A AC - AIR CLEANER
2003 VTX1800C A - WIRE HARNESS
2003 VTX1800C AC - WIRE HARNESS
2003 VTX1800R A - WIRE HARNESS
2003 VTX1800R AC - WIRE HARNESS
2003 VTX1800S A - WIRE HARNESS
2003 VTX1800S AC - WIRE HARNESS
2004 ARX1200N2 A - CYLINDER HEAD COVER
2004 ARX1200N3 A - CYLINDER HEAD COVER
2004 CB900F A - AIR CLEANER
2004 CB900F AC - AIR CLEANER
2004 CBR600F4 A - AIR CLEANER ('01-'06)
2004 CBR600F4 AC - AIR CLEANER ('01-'06)
2004 CBR600RR A - AIR CLEANER
2004 CBR600RR AC - AIR CLEANER
2004 FSC600A AC - THROTTLE BODY
2004 FSC600D AC - THROTTLE BODY
2004 NRX1800DA A - FRAME
2004 NRX1800DA AC - FRAME
2004 NRX1800DB A - FRAME
2004 NRX1800DB AC - FRAME
2004 NRX1800EA A - FRAME
2004 NRX1800EA AC - FRAME
2004 NRX1800EB A - FRAME
2004 NRX1800EB AC - FRAME
2004 RVT1000R A - THROTTLE BODY (ASSY.) ('02-'05)
2004 RVT1000R A - UPPER COWL
2004 RVT1000R AC - THROTTLE BODY (ASSY.) ('02-'05)
2004 RVT1000R AC - UPPER COWL
2004 ST1300 A - THROTTLE BODY (ASSY.)
2004 ST1300A A - THROTTLE BODY (ASSY.)
2004 VFR800 AC - AIR CLEANER
2004 VFR800A AC - AIR CLEANER
2004 VTX1800C A - WIRE HARNESS
2004 VTX1800C AC - WIRE HARNESS
2004 VTX1800N1 A - WIRE HARNESS
2004 VTX1800N1 AC - WIRE HARNESS
2004 VTX1800N2 A - WIRE HARNESS
2004 VTX1800N2 AC - WIRE HARNESS
2004 VTX1800N3 A - WIRE HARNESS
2004 VTX1800N3 AC - WIRE HARNESS
2004 VTX1800R1 A - WIRE HARNESS
2004 VTX1800R1 AC - WIRE HARNESS
2004 VTX1800R2 A - WIRE HARNESS
2004 VTX1800R2 AC - WIRE HARNESS
2004 VTX1800R3 A - WIRE HARNESS
2004 VTX1800R3 AC - WIRE HARNESS
2004 VTX1800S1 A - WIRE HARNESS
2004 VTX1800S1 AC - WIRE HARNESS
2004 VTX1800S2 A - WIRE HARNESS
2004 VTX1800S2 AC - WIRE HARNESS
2004 VTX1800S3 A - WIRE HARNESS
2004 VTX1800S3 AC - WIRE HARNESS
2005 ARX1200N2 A - CYLINDER HEAD COVER
2005 ARX1200N3 A - CYLINDER HEAD COVER
2005 CB900F A - AIR CLEANER
2005 CB900F AC - AIR CLEANER
2005 CBR600F4 A - AIR CLEANER ('01-'06)
2005 CBR600F4 AC - AIR CLEANER ('01-'06)
2005 FSC600A AC - THROTTLE BODY
2005 FSC600D AC - THROTTLE BODY
2005 NRX1800DA A - FRAME
2005 NRX1800DA AC - FRAME
2005 NRX1800DB A - FRAME
2005 NRX1800DB AC - FRAME
2005 NRX1800EA A - FRAME
2005 NRX1800EA AC - FRAME
2005 NRX1800EB A - FRAME
2005 NRX1800EB AC - FRAME
2005 RVT1000R A - THROTTLE BODY (ASSY.) ('02-'05)
2005 RVT1000R A - UPPER COWL
2005 RVT1000R AC - THROTTLE BODY (ASSY.) ('02-'05)
2005 RVT1000R AC - UPPER COWL
2005 ST1300 A - THROTTLE BODY (ASSY.)
2005 ST1300A A - THROTTLE BODY (ASSY.)
2005 ST1300P A - THROTTLE BODY (ASSY.)
2005 VFR800 AC - AIR CLEANER
2005 VFR800A AC - AIR CLEANER
2005 VTX1800C1 A - WIRE HARNESS
2005 VTX1800C1 AC - WIRE HARNESS
2005 VTX1800C2 A - WIRE HARNESS
2005 VTX1800C2 AC - WIRE HARNESS
2005 VTX1800C3 A - WIRE HARNESS
2005 VTX1800C3 AC - WIRE HARNESS
2005 VTX1800F1 A - WIRE HARNESS
2005 VTX1800F1 AC - WIRE HARNESS
2005 VTX1800F2 A - WIRE HARNESS
2005 VTX1800F2 AC - WIRE HARNESS
2005 VTX1800F3 A - WIRE HARNESS
2005 VTX1800F3 AC - WIRE HARNESS
2005 VTX1800N1 A - WIRE HARNESS
2005 VTX1800N1 AC - WIRE HARNESS
2005 VTX1800N2 A - WIRE HARNESS
2005 VTX1800N2 AC - WIRE HARNESS
2005 VTX1800N3 A - WIRE HARNESS
2005 VTX1800N3 AC - WIRE HARNESS
2005 VTX1800R1 A - WIRE HARNESS
2005 VTX1800R1 AC - WIRE HARNESS
2005 VTX1800R2 A - WIRE HARNESS
2005 VTX1800R2 AC - WIRE HARNESS
2005 VTX1800R3 A - WIRE HARNESS
2005 VTX1800R3 AC - WIRE HARNESS
2005 VTX1800S1 A - WIRE HARNESS
2005 VTX1800S1 AC - WIRE HARNESS
2005 VTX1800S2 A - WIRE HARNESS
2005 VTX1800S2 AC - WIRE HARNESS
2005 VTX1800S3 A - WIRE HARNESS
2005 VTX1800S3 AC - WIRE HARNESS
2006 ARX1200N2 A - CYLINDER HEAD COVER
2006 ARX1200N3 A - CYLINDER HEAD COVER
2006 CB900F A - AIR CLEANER
2006 CB900F AC - AIR CLEANER
2006 CBR600F4 A - AIR CLEANER ('01-'06)
2006 CBR600F4 AC - AIR CLEANER ('01-'06)
2006 FSC600A AC - THROTTLE BODY
2006 FSC600D AC - THROTTLE BODY
2006 RVT1000R A - THROTTLE BODY (ASSY.)
2006 RVT1000R A - UPPER COWL
2006 RVT1000R AC - THROTTLE BODY (ASSY.)
2006 RVT1000R AC - UPPER COWL
2006 ST1300 A - THROTTLE BODY (ASSY.)
2006 ST1300A A - THROTTLE BODY (ASSY.)
2006 ST1300PA A - THROTTLE BODY (ASSY.)
2006 VFR800 AC - AIR CLEANER
2006 VFR800A AC - AIR CLEANER
2007 ARX1200N3 A - CYLINDER HEAD COVER
2007 CB900F A - AIR CLEANER
2007 CB900F AC - AIR CLEANER
2007 FSC600A AC - THROTTLE BODY
2007 FSC600D AC - THROTTLE BODY
2007 ST1300 A - THROTTLE BODY (ASSY.)
2007 ST1300A A - THROTTLE BODY (ASSY.)
2007 ST1300PA A - THROTTLE BODY (ASSY.)
2007 VFR800 2AC - AIR CLEANER
2007 VFR800 AC - AIR CLEANER
2007 VFR800A 2AC - AIR CLEANER
2007 VFR800A AC - AIR CLEANER
2008 FSC600A AC - THROTTLE BODY
2008 FSC600D AC - THROTTLE BODY
2008 ST1300 A - THROTTLE BODY (ASSY.)
2008 ST1300A A - THROTTLE BODY (ASSY.)
2008 VFR800 A - AIR CLEANER
2008 VFR800A A - AIR CLEANER
2009 FSC600A AC - THROTTLE BODY
2009 FSC600D AC - THROTTLE BODY
2009 ST1300 A - THROTTLE BODY (ASSY.)
2009 ST1300 A/A - THROTTLE BODY (ASSY.)
2009 ST1300A A - THROTTLE BODY (ASSY.)
2009 ST1300A A/A - THROTTLE BODY (ASSY.)
2009 ST1300PA A - THROTTLE BODY (ASSY.)
2009 ST1300PA A/A - THROTTLE BODY (ASSY.)
2009 VFR800 A - AIR CLEANER
2009 VFR800A A - AIR CLEANER
2010 FSC600A AC - THROTTLE BODY
2010 FSC600D AC - THROTTLE BODY
2010 ST1300 A - THROTTLE BODY (ASSY.)
2010 ST1300A A - THROTTLE BODY (ASSY.)
2011 FSC600A AC - THROTTLE BODY
2011 ST1300PA A - THROTTLE BODY (ASSY.)
2012 FSC600A AC - THROTTLE BODY
2012 ST1300A AC - THROTTLE BODY
2012 ST1300PA AC - THROTTLE BODY (ASSY.)
2013 FSC600A AC - THROTTLE BODY
2013 ST1300A AC - THROTTLE BODY
2013 ST1300PA AC - THROTTLE BODY (ASSY.)
2014 ST1300PA AC - THROTTLE BODY (ASSY.)
2014 VFR800F 2AC - AIR CLEANER
2014 VFR800F AC - AIR CLEANER
2014 VFR800FD 2AC - AIR CLEANER
2015 ST1300PA AC - THROTTLE BODY (ASSY.)
2015 VFR800F 2AC - AIR CLEANER
2015 VFR800F AC - AIR CLEANER
2015 VFR800FD 2AC - AIR CLEANER
2016 ST1300PA AC - THROTTLE BODY (ASSY.)
2017 ST1300PA AC - THROTTLE BODY (ASSY.)
2018 ST1300PA AC - THROTTLE BODY (ASSY.)
The nice thing is that it's still available as a new part. It's an expensive part, so I think I'd do some testing on it before just swapping it out. Could just be a bad connection someplace.
600F4inoober
Jun 9, 2011 01:41 PM
